I am trying to restore the rak4631, which I had updated to the rui3 firmware, to get it back again to the factory arduino. I am following the Device Firmware Upgrade | RAKwireless Documentation Center and I am stuck after having executed
nrfutil.exe dfu serial -pkg rak4631_factory_bootloader.zip -p COM31
The device opened a usb drive that shows UF2 related files.
However, in Arduino IDE I can no longer upload my application. Is there a missing step?
The device is now in bootloader UF2 mode. Normally ArduinoIDE should be able to flash an application.
The error messages in ArduinoIDE are strange? Beside of the UF2 mode, the RAk4631 should show an USB port.
Download this file WisBlock_LowPower_V1.0.0_2023.12.04.13.45.52.uf2.zip.
Unzip it and drag the file WisBlock_LowPower_V1.0.0_2023.12.04.13.45.52.uf2 to the UF2 drive, it will flash a working firmware. WisBlock_LowPower_V1.0.0_2023.12.04.13.45.52.uf2.zip (148.8 KB)
Are the green and blue LED doing anything after you uploaded the UF2 file?
If they are not going on and flickering for a short time, it could be the application is not started.
Reason could be that the SoftDevice was not updated when changing the bootloader.
Try to flash rak4631_factory_softdevice.zip with the adafruit-nrfutil application from a command line
adafruit-nrfutil --verbose dfu serial --package rak4631_factory_softdevice.zip -p <YOUR_USB_+PORT>
You can get the softdevice from the same URL where you got the bootloader ==> Download Center
