I’ve been trying to find the proper settings for RAK5146 and came across two files. Can I find the correct one that works?
Option 1 - global_conf.json.sx1250.EU868.USB
"SX130x_conf": {
"com_type": "USB",
"com_path": "/dev/ttyACM0",
"lorawan_public": true,
"clksrc": 0,
"antenna_gain": 0,
"full_duplex": false,
"fine_timestamp": {
"enable": false,
"mode": "all_sf"
"sx1261_conf": {
"rssi_offset": 0,
"spectral_scan": {
"enable": false,
"freq_start": 867100000,
"nb_chan": 8,
"nb_scan": 2000,
"pace_s": 10
"lbt": {
"enable": false,
"rssi_target": -70,
"channels":[
{"freq_hz": 867100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 867300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 867500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 867700000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 867900000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 868100000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 868300000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 868500000, "bandwidth": 125000, "scan_time_us": 128, "transmit_time_ms": 400},
{"freq_hz": 869525000, "bandwidth": 125000, "scan_time_us": 5000, "transmit_time_ms": 4000},
{"freq_hz": 868300000, "bandwidth": 250000, "scan_time_us": 128, "transmit_time_ms": 400}
"radio_0": {
"enable": true,
"type": "SX1250",
"freq": 867500000,
"rssi_offset": -215.4,
"rssi_tcomp": {"coeff_a": 0, "coeff_b": 0, "coeff_c": 20.41, "coeff_d": 2162.56, "coeff_e": 0},
"tx_enable": true,
"tx_freq_min": 863000000,
"tx_freq_max": 870000000,
"tx_gain_lut":[
{"rf_power": 12, "pa_gain": 0, "pwr_idx": 15},
{"rf_power": 13, "pa_gain": 0, "pwr_idx": 16},
{"rf_power": 14, "pa_gain": 0, "pwr_idx": 17},
{"rf_power": 15, "pa_gain": 0, "pwr_idx": 19},
{"rf_power": 16, "pa_gain": 0, "pwr_idx": 20},
{"rf_power": 17, "pa_gain": 0, "pwr_idx": 22},
{"rf_power": 18, "pa_gain": 1, "pwr_idx": 1},
{"rf_power": 19, "pa_gain": 1, "pwr_idx": 2},
{"rf_power": 20, "pa_gain": 1, "pwr_idx": 3},
{"rf_power": 21, "pa_gain": 1, "pwr_idx": 4},
{"rf_power": 22, "pa_gain": 1, "pwr_idx": 5},
{"rf_power": 23, "pa_gain": 1, "pwr_idx": 6},
{"rf_power": 24, "pa_gain": 1, "pwr_idx": 7},
{"rf_power": 25, "pa_gain": 1, "pwr_idx": 9},
{"rf_power": 26, "pa_gain": 1, "pwr_idx": 11},
{"rf_power": 27, "pa_gain": 1, "pwr_idx": 14}
"radio_1": {
"enable": true,
"type": "SX1250",
"freq": 868500000,
"tx_enable": false
"chan_multiSF_All": {"spreading_factor_enable": [ 5, 6, 7, 8, 9, 10, 11, 12 ]},
"chan_multiSF_0": {"enable": true, "radio": 1, "if": -400000},
"chan_multiSF_1": {"enable": true, "radio": 1, "if": -200000},
"chan_multiSF_2": {"enable": true, "radio": 1, "if": 0},
"chan_multiSF_3": {"enable": true, "radio": 0, "if": -400000},
"chan_multiSF_4": {"enable": true, "radio": 0, "if": -200000},
"chan_multiSF_5": {"enable": true, "radio": 0, "if": 0},
"chan_multiSF_6": {"enable": true, "radio": 0, "if": 200000},
"chan_multiSF_7": {"enable": true, "radio": 0, "if": 400000},
"chan_Lora_std": {"enable": true, "radio": 1, "if": -200000, "bandwidth": 250000, "spread_factor": 7,
"implicit_hdr": false, "implicit_payload_length": 17, "implicit_crc_en": false, "implicit_coderate": 1},
"chan_FSK": {"enable": true, "radio": 1, "if": 300000, "bandwidth": 125000, "datarate": 50000}
"gateway_conf": {
"gateway_ID": "0016c001f157c078",
"server_address": "localhost",
"serv_port_up": 1730,
"serv_port_down": 1732,
"keepalive_interval": 10,
"stat_interval": 120,
"push_timeout_ms": 100,
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
"beacon_period": 0,
"beacon_freq_hz": 869525000,
"beacon_datarate": 9,
"beacon_bw_hz": 125000,
"beacon_power": 14,
"beacon_infodesc": 0
"debug_conf": {
"ref_payload":[
{"id": "0xCAFE1234"},
{"id": "0xCAFE2345"}
"log_file": "loragw_hal.log"
Option 2 - global_conf.eu_863_870.json
"SX130x_conf": {
"com_type": "USB",
"clksrc": 0,
"antenna_gain": 0, /* antenna gain, in dBi */
"fine_timestamp": {
"enable": false,
"mode": "all_sf" /* high_capacity or all_sf */
"radio_0": {
"enable": true,
"type": "SX1250",
"freq": 867500000,
"tx_enable": true,
"tx_gain_lut":[
{"rf_power": 12, "pa_gain": 1, "pwr_idx": 4},
{"rf_power": 13, "pa_gain": 1, "pwr_idx": 5},
{"rf_power": 14, "pa_gain": 1, "pwr_idx": 6},
{"rf_power": 15, "pa_gain": 1, "pwr_idx": 7},
{"rf_power": 16, "pa_gain": 1, "pwr_idx": 8},
{"rf_power": 17, "pa_gain": 1, "pwr_idx": 9},
{"rf_power": 18, "pa_gain": 1, "pwr_idx": 10},
{"rf_power": 19, "pa_gain": 1, "pwr_idx": 11},
{"rf_power": 20, "pa_gain": 1, "pwr_idx": 12},
{"rf_power": 21, "pa_gain": 1, "pwr_idx": 13},
{"rf_power": 22, "pa_gain": 1, "pwr_idx": 14},
{"rf_power": 23, "pa_gain": 1, "pwr_idx": 16},
{"rf_power": 24, "pa_gain": 1, "pwr_idx": 17},
{"rf_power": 25, "pa_gain": 1, "pwr_idx": 18},
{"rf_power": 26, "pa_gain": 1, "pwr_idx": 19},
{"rf_power": 27, "pa_gain": 1, "pwr_idx": 22}
"radio_1": {
"enable": true,
"type": "SX1250",
"freq": 868500000,
"tx_enable": false
"gateway_conf": {
"gateway_ID": "AA555A0000000000",
/* change with default server address/ports */
"server_address": "eu1.cloud.thethings.network",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"stat_interval": 30,
/* forward only valid packets */
/* GPS configuration */
"gps_tty_path": "/dev/ttyAMA0",
/* GPS reference coordinates */
"ref_latitude": 0.0,
"ref_longitude": 0.0,
"ref_altitude": 0,
/* Beaconing parameters */
"beacon_period": 0, /* disable class B beacon, set to 128 enable beacon */
"beacon_freq_nb": 1,
"beacon_freq_step": 0,
"beacon_power": 27
"debug_conf": {
"ref_payload":[
Best,
MM
