Hi everyone,
I am on a bit of a ride for my bachelor’s thesis, and have embarked on embedded rust. This is not my first project with this, but it is the first using LoRa. Now i got this RAK3272s from my supervisor, and have played around a bit with it, and use the examples from the lora-rs repo. But i can simply not get the radio to transmit anything. Paste bin of console, where the setup is visible but when i set it up to connect to a LoRaWAN network nothing happens. Now i’ve had it checked right beside a signal analyzer, where you can visibly see that no signal is sent during any of this, so I am sure that it is just not powered or set to transmitting anything.
Here is a pastebin of the source code. I really hope for some help, because this is quite frustrating
Those files I have looked at, and from what I could gather, then the pin PC13 should be set high when transmissiing and low when receiving, and the opposite is the case for the pin PB8, and I just need to be sure that this is correct?
The txco Configuration was just a desperate attempt to see if it has something to do with a misconfiguration of the HW clock on the radio.
Right thank you very much for the clarification. I’m not really sure why it works now, which is a bit terrifying, but using the MSI(48M) for the sysclk, PC13 for the transmit pin and PB8 for the receive pin it now successfully sends out messages! It can also be that it needed a hard reset from previous configurations, which is what i did just before it working?
I really don’t know much about circuits, so sorry if the terms i’m using are incorrect, I am just reading from my code . The circuit you showed above looks blurred out, is that an internal document?
Hi @carlrowan, I am happy to say that my examples were added to the examples for the lora-rs repo, which can be seen here.
For these examples i used the MSI. Do you think it is possible to use an HSE, because i can see from the block diagram of the RAK3172 that there is a 32.768k which i am guessing is a crystal oscillator clock? And to use that, what frequency should that be set to, is it really an oscillator or an external clock, and should a prescaler be used?
