I recently purchased a WisBlock Meshtastic Starter Kit (US915 Base RAK19007 + Core RAK4631). I’ve had it running on my desk for the past few days powered up via USB while I’d decided how I wanted to implement it.
I’d gathered all the parts, enclosure, etc that I needed to build a solar operated Meshtastic node but I FOOLISHLY assumed that the JST connector polarity was standardized… guess I was wrong! A faint whiff of a burning smell coupled with the board being really hot to the touch is what tipped me off. Had I took a moment to notice the “+” symbol on the PCB I’d have been OK, but it didn’t occur to me.
My situation now is that the unit works fine under USB power, but doesn’t power up through the “BATTERY” input at all.
Because the unit does still communicate normally is it reasonable to assume that the problem may be isolated to the 19007 board? I don’t see any visible damage (burn marks, etc) and have no means to test SMT components at this level, myself.
If it works from USB, but not from battery, you have damaged some parts around the charger/voltage regulator circuit and you are just lucky that it still works from USB supply.
But you can be relative sure the damage is limited to the Base Board.
I haven’t scorched my 19007 board yet, running on USB connection, but I do think it is strange that one must cut the leads on the factory battery configuration and buy a bag of extra leads and switch the + /- leads. Thankful for this community’s information.
As there is no international standard for the polarity on a JST connector, you will always have to check the correct polarity when you buy a cable or a battery.
And you do not have to CUT cables. You can switch the cables on the JST connector of the cable coming from the battery.
