digib
(DB)
July 29, 2021, 11:20am
1
I’ve set up a ChirpStack gateway and have connected a WisBlock Node and Sensor with the Environment_Monitoring.ino installed but even if I can correctly see in my Serial Monitor the data being transmitted like so:
result: Tem:28.25C Hum:29.71% Pres:979.11KPa Gas:18378Ohms
lmh_send ok count 933
my Applications / app /Devices / my_device receives incorrectly decoded data like such:
DecodeDataHex:“0x01, 0x0b, 0x11, 0x0b, 0x8e, 0x00, 0x01, 0x7e, 0x76, 0x00, 0x00, 0x48, 0x0b”
DecodeDataString:"~vH"
I can assume that I am not using the correct Javascript codec functions in my Device-profiles / my_current_device so can you tell me what should I use?
beegee
(Bernd Giesecke)
July 29, 2021, 11:44am
2
Try this encoder in Chirpstack:
// Decode decodes an array of bytes into an object.
// - fPort contains the LoRaWAN fPort number
// - bytes is an array of bytes, e.g. [225, 230, 255, 0]
// - variables contains the device variables e.g. {"calibration": "3.5"} (both the key / value are of type string)
// The function must return an object, e.g. {"temperature": 22.5}
function Decode(fPort, bytes, variables) {
var decoded = {};
switch (bytes[0])
case 0x01: // Environment sensor data
decoded.temperature = (bytes[1] << 8 | bytes[2]) / 100;
decoded.humidity = (bytes[3] << 8 | + bytes[4]) / 100;
decoded.pressure = (bytes[8] | (bytes[7] << 8) | (bytes[6] << 16) | (bytes[5] << 24)) / 100;
decoded.gas = bytes[12] | (bytes[11] << 8) | (bytes[10] << 16) | (bytes[9] << 24);
decoded.cnt = bytes[16] | (bytes[15] << 8) | (bytes[14] << 16) | (bytes[13] << 24);
break;
case 0x02: // Temperature and humidity sensor data
decoded.cnt = bytes[8] | (bytes[7] << 8) | (bytes[6] << 16) | (bytes[5] << 24);
break;
case 0x03: // Ambient light sensor data
decoded.light = (bytes[4] | (bytes[3] << 8) | (bytes[2] << 16) | (bytes[1] << 24)) / 100;
break;
case 0x04: // No sensor data, just counter
decoded.cnt = bytes[4] | (bytes[3] << 8) | (bytes[2] << 16) | (bytes[1] << 24);
break;
case 0x30: // Accelerometer sensor
if (bytes[1] == 0) {
decoded.x_move = "no";
} else {
decoded.x_move = "yes";
if (bytes[2] == 0) {
decoded.y_move = "no";
} else {
decoded.y_move = "yes";
if (bytes[3] == 0) {
decoded.z_move = "no";
} else {
decoded.z_move = "yes";
break;
default:
decoded.unknown = "Unknown data format";
break;
return decoded;
digib
(DB)
July 29, 2021, 11:49am
3
I know I can just use the “like” button but can’t help it not to thank you in words
beegee
(Bernd Giesecke)
July 30, 2021, 12:37pm
4
You’re welcome.
When I started to test all our WisBlock solution examples, I felt like I should write an encoder for all of them. But then I forgot to publish it.
system
(system)
Closed
August 1, 2021, 12:37pm
5
