Hi Rakwireless-Fellows,
So far I’ve used pretty much all the different Rakwireless Gateway versions and my preferred ones are compatible with the RaspberryPi.
Since TTN is migrating to V3 lately, I am thinking about just directly forwarding the decoded payload on the RaspberryPi to be less dependent on what TTN is doing.
Do you have any documentation to do so? Can you please redirect me to any starting point from where I can help myself?
Thank you!
