Allright @cstratton, these are the raw information from gateway:
Fri Mar 19 15:53:22 2021 daemon.info appSrv[31569]: [Uplink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169202,“fCnt”:14,“fPort”:1,“data”:“32392E33432F38342E3746”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:22 2021 daemon.info appSrv[31569]: [Downlink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169202,“fCnt”:14,“fPort”:1,“data”:“32392E33432F38342E3746”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:28 2021 daemon.info appSrv[31569]: [Uplink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169208,“fCnt”:15,“fPort”:1,“data”:“32392E38432F38352E3646”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:28 2021 daemon.info appSrv[31569]: [Downlink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169208,“fCnt”:15,“fPort”:1,“data”:“32392E38432F38352E3646”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:33 2021 daemon.info appSrv[31569]: [Uplink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169213,“fCnt”:16,“fPort”:1,“data”:“33302E31432F38362E3346”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:33 2021 daemon.info appSrv[31569]: [Downlink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169213,“fCnt”:16,“fPort”:1,“data”:“33302E31432F38362E3346”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:38 2021 daemon.info appSrv[31569]: [Uplink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169218,“fCnt”:17,“fPort”:1,“data”:“32392E38432F38352E3646”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:38 2021 daemon.info appSrv[31569]: [Downlink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169218,“fCnt”:17,“fPort”:1,“data”:“32392E38432F38352E3646”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:44 2021 daemon.info appSrv[31569]: [Uplink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169224,“fCnt”:18,“fPort”:1,“data”:“32392E34432F38352E3046”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:44 2021 daemon.info appSrv[31569]: [Downlink] - {“applicationID”:“1”,“applicationName”:“Separated Application”,“devEUI”:“8877665544332211”,“deviceName”:“dev-8877665544332211”,“timestamp”:1616169224,“fCnt”:18,“fPort”:1,“data”:“32392E34432F38352E3046”,“data_encode”:“hexstring”}
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]:
2021-03-19 15:53:44 UTC
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: ### [UPSTREAM] ###
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # RF packets received by concentrator: 5
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # CRC_OK: 100.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # RF packets forwarded: 5 (120 bytes)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # PUSH_DATA datagrams sent: 6 (1214 bytes)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # PUSH_DATA acknowledged: 100.00
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: ### [DOWNSTREAM] ###
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # PULL_DATA sent: 6 (100.00 acknowledged)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # PULL_RESP(onse) datagrams received: 4 (784 bytes)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # RF packets sent to concentrator: 4 (104 bytes)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # BEACON sent so far: 0
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # BEACON rejected: 0
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: ### [JIT] ###
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # SX1301 time (PPS): 3508033071, offset us 0
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: ### [GPS] ###
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # Invalid time reference (age: 1616169224 sec)
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: # no valid GPS coordinates available yet
Fri Mar 19 15:53:44 2021 user.notice lora_pkt_fwd[1466]: ##### END #####
