Hello, I will be heading into the lab to get our device using the RAK4630 FCC tested and certified. Does RAK provide any test firmware for continuous LORA transmission to perform the EMC tests needed to get a device certified?
Thanks,
Luke
Thanks,
Luke
Welcome back to the forum @lukevawkes
Are you using RUI3? In that case, the firmware has a set of RF testing commands that are needed for certification tests.
You can find the manual for the RF Test commands in our Documentation Center ==> AT Command Manual | RAKwireless Documentation Center
If you wrote the firmware with nRF SDK or if you are using the open source Arduino BSP, I am afraid there are no RF test commands.
Thanks for the information. We are not using the RUI3. I found Zephyr has a continuous wave LoRa test function that we can use and will move forward with that.
Thanks,
Luke
