Error. Need Explanation for the following log file of Packet Forwared
I am Stuck at join Request. I am using Rak7244 Gateway
/var/log $ tail -f syslog
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:1, rej:0)
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1922770806
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67613, longitude -120.35428, altitude 444 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### END #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:30:12 GMT”,“lati”:50.67613,“long”:-120.35428,“alti”:444,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [up] PUSH_ACK received in 0 ms
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_ACK received in 0 ms
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:30:42 GMT #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [UPSTREAM] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 1 (158 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA acknowledged: 100.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [DOWNSTREAM] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX errors: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1952249814
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67612, longitude -120.35428, altitude 447 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:30:42 GMT”,“lati”:50.67612,“long”:-120.35428,“alti”:447,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Received pkt from mote: 00000000 (fcnt=0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“rxpk”:[{“tmst”:1976151284,“time”:“2020-03-22T22:31:04.901468Z”,“tmms”:1268951483901,“chan”:6,“rfch”:1,“freq”:905.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:12.5,“rssi”:-43,“size”:23,“data”:“AAAAAAAAAAAAWVMWDK8B6G3NVXmiXlw=”}]}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_RESP received - token[46:133] :slight_smile:
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:1981151284,“freq”:905.1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IEXHrcbvs9LABNx9XtcBYm8gYyKvF5cNb4cUXheOByb8”}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Received pkt from mote: C6ADC745 (fcnt=53939)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“rxpk”:[{“tmst”:1981398052,“time”:“2020-03-22T22:31:10.148235Z”,“tmms”:1268951489148,“chan”:5,“rfch”:1,“freq”:904.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:2.5,“rssi”:-101,“size”:33,“data”:“IEXHrcbvs9LABNx9XtcBYm8gYyKvF5cNb4cUXheOByb8”}]}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Disabling GPS mode for concentrator’s counter…
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753790µs) - drift=50µs
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Enabling GPS mode for concentrator’s counter.
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:31:12 GMT #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 2
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 2 (56 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 3 (700 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 1 (214 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 1 (33 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1982771220
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67614, longitude -120.35431, altitude 446 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:31:12 GMT”,“lati”:50.67614,“long”:-120.35431,“alti”:446,“rxnb”:2,“rxok”:2,“rxfw”:2,“ackr”:100.0,“dwnb”:1,“txnb”:1}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_ACK received in 0 ms
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:31:42 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [UPSTREAM] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 2
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 1 (158 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PUSH_DATA acknowledged: 100.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [DOWNSTREAM] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX errors: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2012249820
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67614, longitude -120.35432, altitude 449 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### END #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:31:42 GMT”,“lati”:50.67614,“long”:-120.35432,“alti”:449,“rxnb”:2,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: [up] PUSH_ACK received in 0 ms
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: Disabling GPS mode for concentrator’s counter…
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753842µs) - drift=52µs
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: Enabling GPS mode for concentrator’s counter.
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:32:12 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2042771596
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67613, longitude -120.35431, altitude 450 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:32:12 GMT”,“lati”:50.67613,“long”:-120.35431,“alti”:450,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:32:42 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 2 (100.00% acknowledged)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2072249827
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67612, longitude -120.35432, altitude 455 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:32:42 GMT”,“lati”:50.67612,“long”:-120.35432,“alti”:455,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753887µs) - drift=45µs
Can you tell me which channel you are using?And check yours chirpstack-network-server configuration files.
I haven’t changed channel because I am using multi channel gateway. Following is the .toml file. Sorry about the format
dsn=“postgres://chirpstack_ns:iot123@localhost/chirpstack_ns?sslmode=disable”
Redis settings
Please note that Redis 2.6.0+ is required.
[redis]
Redis url (e.g. redis://user:password@hostname/0)
For more information about the Redis URL format, see:
https://www.iana.org/assignments/uri-schemes/prov/redis
url=“redis://localhost:6379”
Network-server settings.
[network_server]
Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id=“000000”
LoRaWAN regional band configuration.
Note that you might want to consult the LoRaWAN Regional Parameters
specification for valid values that apply to your region.
See: https://www.lora-alliance.org/lorawan-for-developers
[network_server.band]
name=“EU_863_870”
LoRaWAN network related settings.
[network_server.network_settings]
# Extra channel configuration.
# Use this for LoRaWAN regions where it is possible to extend the by default
# available channels with additional channels (e.g. the EU band).
# The first 5 channels will be configured as part of the OTAA join-response
# (using the CFList field).
# The other channels (or channel / data-rate changes) will be (re)configured
# using the NewChannelReq mac-command.
[[network_server.network_settings.extra_channels]]
frequency=867100000
min_dr=0
max_dr=5
frequency=867300000
min_dr=0
max_dr=5
frequency=867500000
min_dr=0
max_dr=5
frequency=867700000
min_dr=0
max_dr=5
frequency=867900000
min_dr=0
max_dr=5
# Class B settings
[network_server.network_settings.class_b]
# Ping-slot data-rate.
ping_slot_dr=0
# Ping-slot frequency (Hz)
# Set this to 0 to use the default frequency plan for the configured region
# (which could be frequency hopping).
ping_slot_frequency=0
Network-server API
This is the network-server API that is used by ChirpStack Application Server or other
custom components interacting with ChirpStack Network Server.
[network_server.api]
ip:port to bind the api server
bind=“0.0.0.0:8000”
Backend defines the gateway backend settings.
The gateway backend handles the communication with the gateway(s) part of
the LoRaWAN network.
[network_server.gateway.backend]
Backend
type=“mqtt”
# MQTT gateway backend settings.
# This is the backend communicating with the LoRa gateways over a MQTT broker.
[network_server.gateway.backend.mqtt]
# MQTT topic templates for the different MQTT topics.
# The meaning of these topics are documented at:
# https://www.chirpstack.io/gateway-bridge/
# The default values match the default expected configuration of the
# ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
# absolutely needed.
# Event topic template.
event_topic="gateway/+/event/+"
# Command topic template.
# Use:
#   * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
#   * "{{ .CommandType }}" as an substitution for the command type
command_topic_template="gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
# MQTT server (e.g. scheme://host:port where scheme is tcp, ssl or ws)
server="tcp://localhost:1883"
# Connect with the given username (optional)
username=""
# Connect with the given password (optional)
password=""
Metrics collection settings.
[metrics]
Timezone
The timezone is used for correctly aggregating the metrics (e.g. per hour,
day or month).
Example: “Europe/Amsterdam” or “Local” for the the system’s local time zone.
timezone=“Local”
Join-server settings.
[join_server]
Default join-server settings.
This join-server will be used when resolving the JoinEUI is set to false
or as a fallback when resolving the JoinEUI fails.
[join_server.default]
hostname:port of the default join-server
This API is provided by ChirpStack Application Server.
server=“http://localhost:8003”
You can use 8 channels at most, can you confirm whether it is 8 – 15 channels in US915 of RAk7244? If so, please send me your E-mail and I will resend a chirpstack-network-server configuration files for modification.
Yes I am using 8-15 US915 of RAk 7244
I send to your email, please note to check.
I got the mail, will update in a moment. Thanks a lot sir
