Error when compiling on RUI Online Compiler
Hi, I have an error when compiling my code on RUI Online Compiler. My code is from RAK5205, it’s working fine when I modify nothing but now I just added a function and since it’s not working anymore… I can’t find why…
I have a char tab define in the begining :
This is my function (very simple :smiley: )
The moment when I call it, in the main() :
The error on the Online Compiler :
#include "rui.h"
#include "board.h"
#include "bsp.h"
static RUI_RETURN_STATUS rui_return_status;
//join cnt
#define JOIN_MAX_CNT 6
static uint8_t JoinCnt=0;
char omniScan[10] = {-126,0,50,-13,100,-126,80};
RUI_LORA_STATUS_T app_lora_status; //record status
// Bsec iaqSensor;
 * The BSP user functions.
#define LED_1                                   8
#define LED_2                                   9
#define  I2C_SDA  19
#define  I2C_SCL  18
#define BAT_LEVEL_CHANNEL                       20
RUI_GPIO_ST Led_Blue;  //join LoRaWAN successed indicator light
RUI_GPIO_ST Led_Green;  //send data successed indicator light
RUI_GPIO_ST Gps_Power_Ctl;
RUI_GPIO_ST Bat_level;
RUI_I2C_ST I2c_1;
TimerEvent_t Led_Green_Timer;
TimerEvent_t Led_Blue_Timer;  //LoRa send out indicator light
volatile static bool autosend_flag = false;    //auto send flag
static uint8_t a[80]={};    // Data buffer to be sent by lora
static uint8_t sensor_data_cnt=0;  //send data counter by LoRa
const uint8_t level[2]={0,1};
bool IsJoiningflag= false;  //flag whether joining or not status
bool sample_flag = false;  //flag sensor sample record for print sensor data by AT command
bool sample_status = false;  //current whether sample sensor completely
bool sendfull = true;  //flag whether send all sensor data
extern uint8_t NmeaString[];//GPS variate and buffer
extern uint8_t NmeaStringSize;
extern user_store_data_t user_store_data;
extern TimerEvent_t Gps_Cnt_Timer;  //search satellite timer
void rui_lora_autosend_callback(void)  //auto_send timeout event callback
    autosend_flag = true;
    IsJoiningflag = false;
void OnLed_Green_TimerEvent(void)
    rui_timer_stop(&Led_Green_Timer);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Green, high);
    rui_lora_get_status(false,&app_lora_status);//The query gets the current device status
    if(app_lora_status.autosend_status)
        autosend_flag = true;  //set autosend_flag after join LoRaWAN succeeded
void OnLed_Blue_TimerEvent(void)
    rui_timer_stop(&Led_Blue_Timer);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Blue, high);
    rui_lora_get_status(false,&app_lora_status);  //The query gets the current status
    switch(app_lora_status.autosend_status)
        case RUI_AUTO_ENABLE_SLEEP:rui_lora_set_send_interval(RUI_AUTO_ENABLE_SLEEP,app_lora_status.lorasend_interval);  //start autosend_timer after send success
            rui_delay_ms(5);
            break;
        case RUI_AUTO_ENABLE_NORMAL:rui_lora_set_send_interval(RUI_AUTO_ENABLE_NORMAL,app_lora_status.lorasend_interval);  //start autosend_timer after send success
            break;
        default:break;
void bsp_led_init(void)
    Led_Green.pin_num = LED_1;
    Led_Blue.pin_num = LED_2;
    Led_Green.dir = RUI_GPIO_PIN_DIR_OUTPUT;
    Led_Blue.dir = RUI_GPIO_PIN_DIR_OUTPUT;
    Led_Green.pull = RUI_GPIO_PIN_NOPULL;
    Led_Blue.pull = RUI_GPIO_PIN_NOPULL;
    rui_gpio_init(&Led_Green);
    rui_gpio_init(&Led_Blue);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Green,low);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Blue,low);
    rui_delay_ms(200);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Green,high);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Blue,high);
    rui_timer_init(&Led_Green_Timer,OnLed_Green_TimerEvent);
    rui_timer_init(&Led_Blue_Timer,OnLed_Blue_TimerEvent);
    rui_timer_setvalue(&Led_Green_Timer,100);
    rui_timer_setvalue(&Led_Blue_Timer,100);
void bsp_adc_init(void)
    Bat_level.pin_num = BAT_LEVEL_CHANNEL;
    Bat_level.dir = RUI_GPIO_PIN_DIR_INPUT;
    Bat_level.pull = RUI_GPIO_PIN_NOPULL;
    rui_adc_init(&Bat_level);
void bsp_i2c_init(void)
    I2c_1.INSTANCE_ID = 1;
    I2c_1.PIN_SDA = I2C_SDA;
    I2c_1.PIN_SCL = I2C_SCL;
    I2c_1.FREQUENCY = RUI_I2C_FREQ_100K;
    if(rui_i2c_init(&I2c_1) != RUI_STATUS_OK)RUI_LOG_PRINTF("I2C init error.\r\n");
    rui_delay_ms(50);
void bsp_init(void)
    rui_flash_read(RUI_FLASH_USER,&user_store_data,sizeof(user_store_data));  //Init user data from flash
    if(USER_MAGIC_WORD != user_store_data.magic_word)
        user_store_data.magic_word = USER_MAGIC_WORD;
        user_store_data.gps_timeout_cnt = 100;  //set default gps search satellite timer:100s
        user_store_data.gps_format = POINT_BIT4;
        if(rui_flash_write(RUI_FLASH_USER,&user_store_data,sizeof(user_store_data)) == RUI_STATUS_PARAMETER_INVALID )
            RUI_LOG_PRINTF("the length over size.\r\n");
    bsp_led_init();
    bsp_adc_init();
    bsp_i2c_init();
    BME680_Init();
    LIS3DH_Init();
    GpsInit();
uint8_t lpp_cnt=0;  //record lpp package count
typedef struct
{   uint8_t startcnt;
    uint8_t size;
}lpp_data_t;
lpp_data_t lpp_data[10];
void user_lora_send(void)
    uint8_t dr;
    uint16_t ploadsize;
    static uint16_t temp_cnt=0;
    uint16_t temp_size=0;  //send package size
    uint8_t* Psend_start;
    if(autosend_flag)
        rui_lora_get_dr(&dr,&ploadsize);
        if(ploadsize < sensor_data_cnt)
            sendfull = false;  //need subcontract send
            Psend_start = &a[lpp_data[temp_cnt].startcnt];
            if(lpp_data[temp_cnt].size > ploadsize)
                RUI_LOG_PRINTF("ERROR: RUI_AT_LORA_LENGTH_ERROR %d\r\n",RUI_AT_LORA_LENGTH_ERROR);
                sendfull = true;
                lpp_cnt = 0;
                temp_cnt = 0;
                sensor_data_cnt=0;
                        break;
                        break;
                    default:break;
                return;
            for(;temp_cnt <= lpp_cnt; temp_cnt++)
                // UartPrint("lpp_cnt:%d, temp_cnt:%d,temp_size:%d,lpp_data[%d].size:%d,Msize:%d\r\n",lpp_cnt,temp_cnt,temp_size,temp_cnt,lpp_data[temp_cnt].size,ploadsize);
                if(ploadsize < (temp_size + lpp_data[temp_cnt].size))
                    rui_return_status = rui_lora_send(8,Psend_start,temp_size);
                    switch(rui_return_status)
                        case RUI_STATUS_OK:return;
                        default: RUI_LOG_PRINTF("[LoRa]: send error %d\r\n",rui_return_status);
                            break;
                }else
                    if(temp_cnt == lpp_cnt)
                            case RUI_STATUS_OK:RUI_LOG_PRINTF("[LoRa]: send out\r\n");
                                sendfull = true;
                                lpp_cnt = 0;
                                temp_cnt = 0;
                                sensor_data_cnt=0;
                                return;
                                break;
                                break;
                    }else
                        temp_size += lpp_data[temp_cnt].size;
        }else
            rui_return_status = rui_lora_send(8,a,sensor_data_cnt);
                    sendfull = true;
                    lpp_cnt = 0;
                    sensor_data_cnt=0;
                    break;
                            break;
                            break;
                        default:break;
                    break;
extern bsp_sensor_data_t bsp_sensor;
void app_loop(void)
    int temp=0;
    int x,y,z;
    if(app_lora_status.IsJoined)  //if LoRaWAN is joined
        if(autosend_flag)
            autosend_flag=false;
            rui_delay_ms(5);
            if(GPS_get_data(&bsp_sensor.latitude,&bsp_sensor.longitude,&bsp_sensor.altitude) == 0)
                switch(user_store_data.gps_format)
                    case POINT_BIT4:  //standard LPP
                        lpp_data[lpp_cnt].startcnt = sensor_data_cnt;
                        a[sensor_data_cnt++]=0x01;  //11bytes
                        a[sensor_data_cnt++]=0x88;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.latitude * 10000) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.latitude * 10000) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.latitude * 10000)) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.longitude * 10000) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.longitude * 10000) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.longitude * 10000)) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude* 10) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude* 10) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude* 10)) & 0xFF;
                        lpp_data[lpp_cnt].size = sensor_data_cnt - lpp_data[lpp_cnt].startcnt;
                        lpp_cnt++;
                        break;
                    case POINT_BIT6:
                        a[sensor_data_cnt++]=0x01;  //14byte
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.latitude * 1000000) >> 24) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.latitude * 1000000) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.latitude * 1000000) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.latitude * 1000000)) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.longitude * 1000000) >> 24) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.longitude * 1000000) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.longitude * 1000000) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t) (bsp_sensor.longitude * 1000000)) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude * 10) >> 24) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude * 10) >> 16) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude * 10) >> 8) & 0xFF;
                        a[sensor_data_cnt++]=((int32_t)(bsp_sensor.altitude * 10)) & 0xFF;
                        lpp_cnt++;
                        break;
                    default :break;
            BoardBatteryMeasureVolage(&bsp_sensor.voltage);
            bsp_sensor.voltage=bsp_sensor.voltage/1000.0;   //convert mV to V
            RUI_LOG_PRINTF("Battery Voltage = %d.%d V \r\n",(uint32_t)(bsp_sensor.voltage), (uint32_t)((bsp_sensor.voltage)*1000-((int32_t)(bsp_sensor.voltage)) * 1000));
            temp=(uint16_t)round(bsp_sensor.voltage*100.0);
            a[sensor_data_cnt++]=0x08;
            a[sensor_data_cnt++]=0x02;
            a[sensor_data_cnt++]=(temp&0xffff) >> 8;
            a[sensor_data_cnt++]=temp&0xff;
            lpp_cnt++;
            if(BME680_get_data(&bsp_sensor.humidity,&bsp_sensor.temperature,&bsp_sensor.pressure,&bsp_sensor.resis)==0)
                a[sensor_data_cnt++]=0x07;
                a[sensor_data_cnt++]=0x68;
                a[sensor_data_cnt++]=( bsp_sensor.humidity / 500 ) & 0xFF;
                lpp_cnt++;
                a[sensor_data_cnt++]=0x06;
                a[sensor_data_cnt++]=0x73;
                a[sensor_data_cnt++]=(( bsp_sensor.pressure / 10 ) >> 8 ) & 0xFF;
                a[sensor_data_cnt++]=(bsp_sensor.pressure / 10 ) & 0xFF;
                lpp_cnt++;
                a[sensor_data_cnt++]=0x67;
                a[sensor_data_cnt++]=(( bsp_sensor.temperature / 10 ) >> 8 ) & 0xFF;
                a[sensor_data_cnt++]=(bsp_sensor.temperature / 10 ) & 0xFF;
                lpp_cnt++;
                a[sensor_data_cnt++] = 0x04;
				a[sensor_data_cnt++] = 0x02; //analog output
				a[sensor_data_cnt++] = (((int32_t)(bsp_sensor.resis / 10)) >> 8) & 0xFF;
				a[sensor_data_cnt++] = ((int32_t)(bsp_sensor.resis / 10 )) & 0xFF;
                lpp_cnt++;
            if(lis3dh_get_data(&bsp_sensor.triaxial_x,&bsp_sensor.triaxial_y,&bsp_sensor.triaxial_z) == 0)
                x=(int)(bsp_sensor.triaxial_x);y=(int)(bsp_sensor.triaxial_y);z=(int)(bsp_sensor.triaxial_z);
                a[sensor_data_cnt++]=0x03;
                a[sensor_data_cnt++]=0x71;
                a[sensor_data_cnt++]=(x>>8) & 0xff;
                a[sensor_data_cnt++]=x & 0xff;
                a[sensor_data_cnt++]=(y>>8) & 0xff;
                a[sensor_data_cnt++]=y & 0xff;
                a[sensor_data_cnt++]=(z>>8) & 0xff;
                a[sensor_data_cnt++]=z & 0xff;
                lpp_cnt++;
	        if(sensor_data_cnt != 0)
                sample_status = true;
                sample_flag = true;
                RUI_LOG_PRINTF("\r\n");
                user_lora_send();
            else
                rui_lora_set_send_interval(RUI_AUTO_DISABLE,0);  //stop it auto send data if no sensor data.
    }else if(app_lora_status.autosend_status != RUI_AUTO_DISABLE)
        if(IsJoiningflag == false)
            IsJoiningflag = true;
            if(app_lora_status.join_mode == RUI_OTAA)
                rui_return_status = rui_lora_join();
                    case RUI_STATUS_OK:RUI_LOG_PRINTF("OTAA Join Start...\r\n");break;
                    case RUI_LORA_STATUS_PARAMETER_INVALID:RUI_LOG_PRINTF("ERROR: RUI_AT_LORA_PARAMETER_INVALID %d\r\n",RUI_AT_LORA_PARAMETER_INVALID);
                                break;
                                break;
                            default:break;
                        break;
                    default: RUI_LOG_PRINTF("ERROR: LORA_STATUS_ERROR %d\r\n",rui_return_status);
                        if(app_lora_status.lora_dr > 1)rui_lora_set_dr(app_lora_status.lora_dr-1);
                                break;
                                break;
                            default:break;
                        break;
 * LoRaMac callback functions
 * * void LoRaReceive_callback(RUI_RECEIVE_T* Receive_datapackage);//LoRaWAN callback if receive data
 * * void LoRaP2PReceive_callback(RUI_LORAP2P_RECEIVE_T *Receive_P2Pdatapackage);//LoRaP2P callback if receive data
 * * void LoRaWANJoined_callback(uint32_t status);//LoRaWAN callback after join server request
 * * void LoRaWANSendsucceed_callback(RUI_MCPS_T status);//LoRaWAN call back after send data complete
    char hex_str[3] = {0};
    RUI_LOG_PRINTF("at+recv=%d,%d,%d,%d", Receive_datapackage->Port, Receive_datapackage->Rssi, Receive_datapackage->Snr, Receive_datapackage->BufferSize);
    if ((Receive_datapackage->Buffer != NULL) && Receive_datapackage->BufferSize) {
        RUI_LOG_PRINTF(":");
        for (int i = 0; i < Receive_datapackage->BufferSize; i++) {
            sprintf(hex_str, "%02x", Receive_datapackage->Buffer[i]);
            RUI_LOG_PRINTF("%s", hex_str);
    char hex_str[3]={0};
    RUI_LOG_PRINTF("at+recv=%d,%d,%d:", Receive_P2Pdatapackage -> Rssi, Receive_P2Pdatapackage -> Snr, Receive_P2Pdatapackage -> BufferSize);
    for(int i=0;i < Receive_P2Pdatapackage -> BufferSize; i++)
        sprintf(hex_str, "%02X", Receive_P2Pdatapackage -> Buffer[i]);
        RUI_LOG_PRINTF("%s",hex_str);
    static int8_t dr;
    if(status)  //Join Success
        JoinCnt = 0;
        RUI_LOG_PRINTF("OK Join Success\r\n");
        rui_gpio_rw(RUI_IF_WRITE,&Led_Green, low);
        rui_timer_start(&Led_Green_Timer);
    }else
        if(JoinCnt<JOIN_MAX_CNT) // Join was not successful. Try to join again
            JoinCnt++;
            RUI_LOG_PRINTF("[LoRa]:Join retry Cnt:%d\n",JoinCnt);
            rui_lora_join();
        else   //Join failed
            RUI_LOG_PRINTF("ERROR: %d\r\n",RUI_AT_LORA_INFO_STATUS_JOIN_FAIL);
            JoinCnt=0;
void LoRaWANSendsucceed_callback(RUI_MCPS_T mcps_type,RUI_RETURN_STATUS status)
    if(sendfull == false)
        return;
    if(status == RUI_STATUS_OK)
        switch( mcps_type )
            case RUI_MCPS_UNCONFIRMED:
                RUI_LOG_PRINTF("OK \r\n");
                break;
            case RUI_MCPS_CONFIRMED:
                break;
            case RUI_MCPS_MULTICAST:
                break;
            case RUI_MCPS_PROPRIETARY:
                break;
            default:
                break;
	}else if(status != RUI_AT_LORA_INFO_STATUS_ADDRESS_FAIL)RUI_LOG_PRINTF("ERROR: %d\r\n",status);
    rui_delay_ms(10);
    rui_gpio_rw(RUI_IF_WRITE,&Led_Blue, low);
    rui_timer_start(&Led_Blue_Timer);
void affichageOmniScan(){
	RUI_LOG_PRINTF("Le tableau :", omniScan[0]);
void LoRaP2PSendsucceed_callback(void)
 * The RUI is used to receive data from uart.
void rui_uart_recv(RUI_UART_DEF uart_def, uint8_t *pdata, uint16_t len)
    switch(uart_def)
        case RUI_UART1://process code if RUI_UART1 work at RUI_UART_UNVARNISHED
                rui_lora_send(8,pdata,len);
            }else
                RUI_LOG_PRINTF("ERROR: %d\r\n",RUI_AT_LORA_NO_NETWORK_JOINED);
            break;
        case RUI_UART3:
             *  process code with RUI_UART3:In RAK5205 board is used for GPS
            if( ( *pdata == '$' ) || ( NmeaStringSize >= 1024 ) )
                NmeaStringSize = 0;
            NmeaString[NmeaStringSize++] = ( int8_t )*pdata;
            if( *pdata == '\n' )
                NmeaString[NmeaStringSize++] = '\0';
                GpsParseGpsData( ( int8_t* )NmeaString, NmeaStringSize );
            /*****************************user code end***************************/
            break;
        default:break;
 * sleep and wakeup callback
void bsp_sleep(void)
             * user process code before enter sleep
	GpsStop();  //close gps before entry sleep mode
	rui_timer_stop(&Gps_Cnt_Timer);  //stop search satellite timer
extern bool gps_timeout_flag;
void bsp_wakeup(void)
             * user process code after exit sleep
    sendfull = true;  //clear subcontract send flag
    sample_status = false;  //clear sample flag
    gps_timeout_flag = true;  //clear serch Satellite flag
    GpsInit();
    bsp_i2c_init();
    BME680_Init();
    LIS3DH_Init();
    rui_delay_ms(50);
 * the app_main function
void main(void)
    rui_uart_mode_config(RUI_UART3,RUI_UART_USER); //Forces UART3 to be configured in RUI_UART_USER mode
    rui_init();
    bsp_init();
     * Register LoRaMac callback function
    rui_lora_register_recv_callback(LoRaReceive_callback);
    rui_lorap2p_register_recv_callback(LoRaP2PReceive_callback);
    rui_lorajoin_register_callback(LoRaWANJoined_callback);
    rui_lorasend_complete_register_callback(LoRaWANSendsucceed_callback);
    rui_lorap2p_complete_register_callback(LoRaP2PSendsucceed_callback);
     * Register Sleep and Wakeup callback function
    rui_sensor_register_callback(bsp_wakeup,bsp_sleep);
     *The query gets the current status
     *Init OK ,print board status and auto join LoRaWAN
    switch(app_lora_status.work_mode)
		case RUI_LORAWAN:
            if(app_lora_status.autosend_status)RUI_LOG_PRINTF("autosend_interval: %us\r\n", app_lora_status.lorasend_interval);
            RUI_LOG_PRINTF("Current work_mode:LoRaWAN,");
                RUI_LOG_PRINTF(" join_mode:OTAA,");
                if(app_lora_status.MulticastEnable)
                    RUI_LOG_PRINTF(" MulticastEnable:true.\r\n");
                }else
                    RUI_LOG_PRINTF(" MulticastEnable: false,");
                switch(app_lora_status.class_status)
                    case RUI_CLASS_A:RUI_LOG_PRINTF(" Class: A\r\n");
                        break;
                    case RUI_CLASS_B:RUI_LOG_PRINTF(" Class: B\r\n");
                        break;
                    case RUI_CLASS_C:RUI_LOG_PRINTF(" Class: C\r\n");
                        break;
                    default:break;
            }else if(app_lora_status.join_mode == RUI_ABP)
                RUI_LOG_PRINTF(" join_mode:ABP,");
                }else
                        break;
                        break;
                        break;
                    default:break;
                if(rui_lora_join() == RUI_STATUS_OK)//join LoRaWAN by ABP mode
                    LoRaWANJoined_callback(1);  //ABP mode join success
			break;
		default: break;
    RUI_LOG_PRINTF("Initialization OK \r\n");
    RUI_LOG_PRINTF("Bonjour, bienvenue sur le device LoRaWAN PULETS \r\n");
    affichageOmniscan();
    while(1)
        rui_lora_get_status(false,&app_lora_status);//The query gets the current status
        rui_running();
            case RUI_LORAWAN:
                if(!sample_status)app_loop();
                else user_lora_send();
                break;
            case RUI_P2P:
                 * user code at LoRa P2P mode
                break;
            default :break;
affichageOmniScan is not affichageOmniscan
The compiler is sensitive to upper/lower case :grin:
It is very embarassing rn… But thank you !!
While I’m here I would like to print this char tab on my uart port but it dosnt appear on the serial tool…
#include "rui.h"
#include "board.h"
#include "bsp.h"
//join cnt
// Bsec iaqSensor;
#define LED_1                                   8
#define LED_2                                   9
#define  I2C_SDA  19
#define  I2C_SCL  18
RUI_I2C_ST I2c_1;
            rui_delay_ms(5);
            break;
            break;
        default:break;
    rui_delay_ms(200);
    rui_delay_ms(50);
void bsp_init(void)
    bsp_led_init();
    bsp_adc_init();
    bsp_i2c_init();
    BME680_Init();
    LIS3DH_Init();
    GpsInit();
typedef struct
{   uint8_t startcnt;
    uint8_t size;
}lpp_data_t;
    uint8_t dr;
    uint16_t ploadsize;
    if(autosend_flag)
                sendfull = true;
                lpp_cnt = 0;
                temp_cnt = 0;
                sensor_data_cnt=0;
                        break;
                        break;
                    default:break;
                return;
                            break;
                }else
                                sendfull = true;
                                lpp_cnt = 0;
                                temp_cnt = 0;
                                sensor_data_cnt=0;
                                return;
                                break;
                                break;
                    }else
        }else
                    sendfull = true;
                    lpp_cnt = 0;
                    sensor_data_cnt=0;
                    break;
                            break;
                            break;
                        default:break;
                    break;
void app_loop(void)
    int temp=0;
    int x,y,z;
        if(autosend_flag)
            rui_delay_ms(5);
                        lpp_cnt++;
                        break;
                    case POINT_BIT6:
                        lpp_cnt++;
                        break;
                    default :break;
            lpp_cnt++;
                lpp_cnt++;
                lpp_cnt++;
                lpp_cnt++;
                lpp_cnt++;
                lpp_cnt++;
                sample_flag = true;
                user_lora_send();
            else
                                break;
                                break;
                            default:break;
                        break;
                                break;
                                break;
                            default:break;
                        break;
    static int8_t dr;
        JoinCnt = 0;
    }else
            JoinCnt++;
            rui_lora_join();
        else   //Join failed
            JoinCnt=0;
        return;
        switch( mcps_type )
                break;
                break;
                break;
                break;
            default:
                break;
    rui_delay_ms(10);
    rui_timer_start(&Led_Blue_Timer); }
    switch(uart_def)
            }else
            break;
        case RUI_UART3:
                NmeaStringSize = 0;
            break;
        default:break;
    GpsInit();
    bsp_i2c_init();
    BME680_Init();
    LIS3DH_Init();
    rui_delay_ms(50);
void main(void)
    rui_init();
    bsp_init();
		case RUI_LORAWAN:
                }else
                        break;
                        break;
                        break;
                    default:break;
                }else
                        break;
                        break;
                        break;
                    default:break;
			break;
		default: break;
    RUI_LOG_PRINTF("Voici le tableau OmniScan :", omniScan[0], omniScan[1], omniScan[2], omniScan[3], "\r\n");
    while(1)
        rui_running();
            case RUI_LORAWAN:
                break;
            case RUI_P2P:
                break;
            default :break;
You probably want to review how format specifiers work in a printf-style function. You’re using as if it were concatenating items, but that’s not how it works.
Ok I’m not sure I really understand what I’m supposed to do but anyway that’s not my main goal. My project is to send this char tab to my gateway. The RAK5205 is already set and connected to the gateway. I know I must use the RUI_lora_send API but it’s not clear how I have to use it ?
Especially, I have troubles to understand this line (166) :
I get that Psend_start is the adress of the data we want to send, the & is to get the adress of it, a is a tab where we stock the data but I don’t get the end [lpp_data[temp_cnt].startcnt];…
If someone can help me out on this one …
What is the use of the variable sensor_data_cnt in the void user_lora_send(void) function?
Same for that loop : for(;temp_cnt <= lpp_cnt; temp_cnt++) line 186
It is the same format you would use with printf:
RUI_LOG_PRINTF("Voici le tableau OmniScan : %d %d %d %d\r\n", omniScan[0], omniScan[1], omniScan[2], omniScan[3]);
For RUI commands in general, you can find the commands in the RUI Documentation Center
==> RUI LoRa General Format | RAKwireless Documentation Center
Example:
		uint8_t sample_data[5];
		uint8_t len = 0;
		sample_data[len++] = 0x01; // Cayenne LP channel 1
		sample_data[len++] = 0x02; // Cayenne Analog input
		uint16_t analog_lpp = adc_value / 10;
		sample_data[len++] = (uint8_t)(analog_lpp >> 8);
		sample_data[len++] = (uint8_t)(analog_lpp & 0x00FF);
		sample_data[len++] = 0x02;		// Cayenne LP channel 2
		sample_data[len++] = 0x00;		// Cayenne Digital input
		sample_data[len++] = pin_level; // GPIO status
		sample_data[len++] = 0x03;		// Cayenne LP channel 3
		sample_data[len++] = output_state; // GPIO status
		int send_result = rui_lora_send(f_port, sample_data, len);
		if (send_result != RUI_STATUS_OK)
			RUI_LOG_PRINTF("Send error %d\r\n", send_result);
