I am trying to get the bosch library to work on my rak 4631 with my environment sensor so I can get aqi readings instead of hms. I installed the bsec library, but am getting this error when I try to compile
Here is the traceback
Library BSEC_Software_Library has been declared precompiled:
Precompiled library in "/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard/fpv4-sp-d16-hard" not found
Precompiled library in "/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard" not found
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::beginCommon()':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:157: undefined reference to `bsec_init'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::getVersion()':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:317: undefined reference to `bsec_get_version'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:180: undefined reference to `bsec_update_subscription'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::setState(unsigned char*)':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:286: undefined reference to `bsec_set_state'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::readProcessData(long long, bsec_bme_settings_t)':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:385: undefined reference to `bsec_do_steps'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: libraries/BSEC_Software_Library/BSEC_Software_Library.a(bsec.cpp.o): in function `Bsec::run(long long)':
/Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:202: undefined reference to `bsec_init'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:210: undefined reference to `bsec_update_subscription'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:216: undefined reference to `bsec_sensor_control'
/Users/A1/Library/Arduino15/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /Users/A1/Documents/Arduino/libraries/BSEC_Software_Library/src/bsec.cpp:246: undefined reference to `bsec_get_state'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board WisBlock Core RAK4631 Board.
Here is the code
#include "bsec.h"
// Helper functions declarations
void checkIaqSensorStatus(void);
void errLeds(void);
// Create an object of the class Bsec
Bsec iaqSensor;
String output;
// Entry point for the example
void setup(void)
Wire.begin();
iaqSensor.begin(BME680_I2C_ADDR_PRIMARY, Wire);
output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
Serial.println(output);
checkIaqSensorStatus();
bsec_virtual_sensor_t sensorList[10] = {
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_LP);
// Print the header
output = "Timestamp [ms], raw temperature [°C], pressure [hPa], raw relative humidity [%], gas [Ohm], IAQ, IAQ accuracy, temperature [°C], relative humidity [%], Static IAQ, CO2 equivalent, breath VOC equivalent";
// Function that is looped forever
void loop(void)
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
output = String(time_trigger);
output += ", " + String(iaqSensor.rawTemperature);
output += ", " + String(iaqSensor.pressure);
output += ", " + String(iaqSensor.rawHumidity);
output += ", " + String(iaqSensor.gasResistance);
output += ", " + String(iaqSensor.iaq);
output += ", " + String(iaqSensor.iaqAccuracy);
output += ", " + String(iaqSensor.temperature);
output += ", " + String(iaqSensor.humidity);
output += ", " + String(iaqSensor.staticIaq);
output += ", " + String(iaqSensor.co2Equivalent);
output += ", " + String(iaqSensor.breathVocEquivalent);
} else {
// Helper function definitions
if (iaqSensor.status != BSEC_OK) {
if (iaqSensor.status < BSEC_OK) {
output = "BSEC error code : " + String(iaqSensor.status);
for (;;)
errLeds(); /* Halt in case of failure */
} else {
output = "BSEC warning code : " + String(iaqSensor.status);
if (iaqSensor.bme680Status != BME680_OK) {
if (iaqSensor.bme680Status < BME680_OK) {
output = "BME680 error code : " + String(iaqSensor.bme680Status);
for (;;)
} else {
output = "BME680 warning code : " + String(iaqSensor.bme680Status);
void errLeds(void)
pinMode(LED_BUILTIN, OUTPUT);
delay(100);
delay(100);
