I was trying to setup EVK-RAK833 board, RAK634 + RAK833, but I could not find the compiled binaries in the downloads section. Can someone point me to the firmware section?
Regards,
Akshai M
Regards,
Akshai M
Hi @akshaim,
You can download the compiled binaries here:
https://downloads.rakwireless.com/LoRa/RAK2247-Mini-PCIe/MT7628-Firmware/
These files can be used for RAK2247 and RAK833 both.
Hi @Fomi,
Thank for the quick reply. I tried openwrt-15.05.1-ramips-mt7628-mt7628-squashfs-sysupgrade but the following error occurs. The device is caught up in constant reboots. I followed this guide to flash the firmware.
##### The CPU freq = 575 MHZ ####
estimate memory size =128 Mbytes
RESET MT7628 PHY!!!!!!
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP.
