I have an external sensor connected via some test points on the RAK5010 (SDA and SCL) and power from ground/VDD (1.8v). It’s working as expected.
The issue I have is that the sensor is drawing power 100% of the time and battery life is significantly lowered.
It’s a very simple sensor with the main SGP30 chip, a couple resistors and a cap.
I’m looking at redesigning the sensor to have switching transistor for power but before I do, can I used one of the I/O pins for Ground? That is set it as an Output, set it High to turn off the ground, then set Low to engage ground to drive the sensor?
If so, is there a better pin on the RAK5010 to use? IO1, IO2, IO3, IO4?
If not, then I’ll probably use one of those pins to drive a Transistor to engage power to my sensor but wanted to ask if there might be a solution already available on the RAK5010.
