Thank you, that was helpful. I was able to upload the RAK4631_dfu_package instead of “_latest_package” to my Helium Field Mapper.
Now in terminal I see AT+VER=? as RUI_4.2.1_RAK4631 and it responds to AT+BOOT but will not accept the load for any of the three files:
rak4631_factory_application.zip
rak4631_factory_bootloader.zip
rak4631_factory_softdevice.zip
I have tried on a windows machine using Nrfutil as well as MacOS with nrfutil-mac.1 which was successfully used for the first flash mentioned above.
I’ve written technical documentation before and please note; you document for Converting RAK4631-R to RAK4631 makes assumptions that you have internally that customers may not have which could be important.
Let me know if these are correct:
RAK4631-R is the same module with the RUI programability.
RAK4631 - is the same module with Arduino programability.
Adafruit-nrfutil only speaks RUI programability
Nrfutil only speaks Arduino programability
For Mac and Linux within that doc, you are missing some steps to convert the radio to Arduino mode. I made assumptions and used the same command line to attempt the update of ~application ~bootloader and ~softdevice but get errors such as: Failed to execute script ‘main’ due to unhandled exception
I can still talk to my device over terminal, but the display no longer loads the Helium mapper.
RAK4631-R is the same module with the RUI programability. Correct
RAK4631 - is the same module with Arduino programability. Correct
Adafruit-nrfutil only speaks RUI programability Wrong
Nrfutil only speaks Arduino programability Wrong
adafruit-nrfutil is used when the existing bootloader on the device is Arduino based
nrfutil is used when the existing bootloader on the device is RUI3 based
When switching from Arduino to RUI3:
The RUI3 bootloader is flashed with adafruit-nrfutil, because only adafruit-nrfutil can talk to a Arduino bootloader.
Once the RUI3 bootloader is flashed the tool required to flash is nrfutil
When switching from RUI3 to Arduino
The Arduino bootloader is flashed with nrfutil, because only nrfutil can talk to a RUI3 bootloader.
Once the Arduino bootloader is flashed the tool required is adafruit-nrfutil
Thanks for the clarity on the flash utilities. That wasn’t obvious within the other docs.
You started to type “When s” and ended the message.
I’m still not able to get this to load the DFU Arduino compatible firmware.
I can only get this file to flash successfully:
nrfutil-mac.1 dfu usb-serial -pkg RAK4631_dfu_package.zip -p /dev/cu.usbmodemDFBD9AC6E83D1
[####################################] 100%
Within terminal afterward I see:
AT+VER=RUI_4.2.1_RAK4631
Once the RUI3 bootloader is flashed the tool required is nrfutil
is flashing the RUI3 firmware with bootloader, softdevice and AT command application. If you see AT+VER=RUI_4.2.1_RAK4631, it was successful flashed and you can flash you custom RUI3 based firmware on the device.
But that means that you still have the RUI3 bootloader on the device.
