Hello guys,
what would be the best way to fix a RAK19011 project to the base of a polycase enclosure?
Hello guys,
Can you give more details about the Polycase enclosure? They have many enclosure types.
I designed multiple mounting plates for different enclosure (Polycase, Bopla, Hammond, Takachi).
It’s this enclosure:
https://www.polycase.com/zh-100804
I want to mount the RAK to the internal mounting panel, which is this one:
https://www.polycase.com/zx-1008k
Never tested that enclosure.
The easiest way will be to use 2.5mm stand-offs, make holes in the mounting panel. Screw the stand-offs in the mounting panel and then put the WisBlock Base Board on the stand-offs.
You can get the stand-offs for example from Amazon
For the distances between the stand-offs to match with the Base Board, you can find them in our Documentation Center RAK19011 ==> Board Dimensions
