Flashing Meshtastic FW on RAK4630 with RAKDAP
I would like to know if anyone has managed to flash the meshtastic fw through the RAKDAP, I tried taking the .hex file from the releases and using the method used for the bootloader, but this didnt seem to work.
I have some new boards I designed and I ideally dont want to have to use the USB connection. (I have proved that this works though)
Any help is greatly appreciated,
Ben
The Meshtastic HEX files do not contain the bootloader.
If you do a chip-erase, you delete the bootloader and need to flash both bootloader and Meshtastic.
Try to avoid chip-erase and flash the Meshtastic file only.
