Running on RAK4631
I’ve got the simplest task I can think of
void ProcessReceivedDataTask(void * parameter)
configASSERT(((QueueHandle_t)parameter) != NULL);
for( ;; )
Serial.println("task running");
vTaskDelay(1000);
taskYIELD();
and it is created in setup() as follows
QueueHandle_t _messageQueue = xQueueCreate(64, sizeof(struct int));
TaskHandle_t _taskHandle = NULL;
BaseType_t xReturned = xTaskCreate(ProcessReceivedDataTask, "DATA_PROC", 1000, (void *)_messageQueue, tskIDLE_PRIORITY, &_taskHandle);
if(xReturned != pdPASS)
while(true){
Serial.println("Failed to create data processing task");
delay(100);
The program does not hang on Serial.println("Failed to create data processing task"); however, the task does not send any output to the Serial port.
Does anyone have any ideas of why this might be the case? OR should I be directing this query to the FreeRTOS forum?
