Gateway D4H Rak7248 - Quickstart
Hi all!
Can someone help me starting with Wisgate D4H (7248 developer gateway?)
This is the quickstart. RAKwireless Documentation Center
But, nothing said about configuration, ssh access, etc… I’ve spent 2 hours for finding documentation without success… What’s the ip address of this product? DHCP wasn’t enable… What’s the password of the network wifi generated by device?
Unless you are going Helium, the Pi3/Pi4 based gateways use the same Pi image, so one of the other ones should get you started, like this:
https://docs.rakwireless.com/Product-Categories/WisGate/RAK7244/Quickstart/
Hi @ciclonite,
Apologies for the confusion. As Nick said, you can use this guide for reference about the quickstart: RAKwireless Documentation Center
Best Regards
@Nikola @nmcc Thanks for reply. Ok, i’ll use those instructions!
Have a nice day.
3 years later… Could you connect? I have the image shipped when I bought the Rak Hotspot V2 Helium. (Rak7248). I still have problems with ssh connection too. Port 22 is closed. I dont see WiFi access neither.
Must we burn a new image?
Hello @chbinousamy,
RAK7248, though hardwarely similar to RAK hotspot, is not a RAK hotspot, but a Developer Gateway. You can not expect the same functionality (ssh, WiFi AP, etc.) from your miner. If you reflash it with the correct firmware you can repurpose the hardware as a gateway, rather than a hotspot.
If you are interested in the hotspot, better look for info on the original site of MNTD here: https://support.getmntd.com/hc/en-us/articles/6641899793559-MNTD-Quickstart
