Hi, im using Wisgate edge pro V2 (Rak 7289V2) with firmware wisgate OS 2.2.8
for LNS i’m using Chirpstack V4 installed on docker on my pc, i used mode lora package forward using MQTT protobuff V4, got an issue, when i checked on chirpstack while i send payload, it shows gwtime and nstime didn’t sync
i was tried to sync in the gateway setting by using sync via web browser, and it shows the time already same with current time
but when i checked on gateway “overview” menu, it shows wrong time
i also try to adding NTP client on setting, because my gateway location is in indonesia, so i put Indonesia NTP server and trying for reboot the gateway and nothing happened.
i thought it make an issue for my sensor with far distance to join this gateway, because the gateway will ignore if the time has a huge different time , help me please
