Gateway working with US915 frequency band. Is it supports AU915 Frequency?
Yes ,It can support both US915 and AU915. You need to select the Frequency setting on the web page firstly.
Hi @ravi for which Gateway you are asking? If you are asking for RPi based gateways, and using RAK image, you can change the Frequency pan from gateway-config menu. Just run this in the Pi Shell.
