I am currently facing a GNSS issue with a RAK8213 module and I would like to ask for your help.
My setup
- Module: RAK8213
- Platform: RAK 7391
- GNSS antenna: connected to the correct GNSS connector
- I also placed the antenna outside near a window / open area
- LTE works correctly, but GNSS never gets a valid fix
Problem description
The GNSS seems to start correctly, because I can read NMEA messages, but I never get valid coordinates.
The messages I continuously receive are:
$GPVTG,T,M,N,K,N*2C
$GPGSA,A,1,*1E
$GPGGA,0,66
$GPRMC,V,N53
These messages repeat again and again, with:
* no latitude / longitude
* no valid fix
* no satellites used
So the GNSS is outputting NMEA, but it never reaches a position fix.
## What I already tested
I have been working on this problem for about **one month**.
I already tested the following:
* checked that the **GNSS antenna is connected to the correct pin**
* placed the antenna outside for better sky visibility
* changed the **LTE/GNSS module** with another one
* the antenna works on another platform
* repeated many GNSS tests and AT commands
* restarted GNSS multiple times
* tested different serial ports
* stopped ModemManager during AT tests
## AT command tests
I already tested several commands such as:
```text
AT
AT+QGPS?
AT+QGPS=1
AT+QGPSEND
AT+QGPSLOC=2
AT+QGPSGNMEA="GGA"
AT+QGPSGNMEA="RMC"
AT+QGPSGNMEA="GSV"
AT+QGPSCFG="outport","usbnmea"
AT+QGPSCFG="nmeasrc",1
AT+QGPSCFG="gnssconfig",1
But the result is always the same:
- GNSS starts
- NMEA output is present
- but no valid coordinates are obtained
Any help or feedback would be greatly appreciated.
Thank you.
