I want to build a sensor module with Meshtastic. A PIR sensor is connected to IO1 on my 19007 base board and the core module is a 1931.
My question is, which GPIO number in Meshtastic refers to this Input (and IO2, AIN1).
Thanks!
Thanks!
Hi Robert,
I am not sure on PIR sensor implementation of meshtastic but I can share you the IO numbers of the WisBlock pins.
(Only for RAK4631/RAK4631)
IO1 - P0.07 (7 in Meshtastic)
IO2 - P1.02 (34 in Meshtastic)
AIN1 - P0.31 (31 in Meshtastic)
GPIO numbers might be different depending on the used WisBlock Core module.
1931 is not a valid Core name. What do you use?
Possible Core modules are:
RAK4631 (RAK4630 on the label)
RAK11310 (RAK11300 on the label)
RAK3312 (RAK3112 on the label)
