RAK19007 with 4631 module running on VSCODE with great results and will add now RAK12500 gps
is there a GPS example (not LoRaWan?) available?
or just confirmation that:
TinyGPS library should be used
gpsSerial.begin(GPS_BAUD, SERIAL_8N1, GPS_TX, GPS_RX);
9600 baud rate?
should gps unit be powered by a special VCC pin? or being reseted before using?
GPS_TX and GPS_RX pins are?
beegee
(Bernd Giesecke)
October 15, 2024, 11:38am
2
WisBlock repo, examples:
Using I2C (faster, easier, lower power consumption
Using Serial , slower, higher power consumption
great! will try to use the I2C then and report as result are achieved
Ublox library as I2C example worked fine!
Slot A was recognized right away as I used the Wire.begin() for this I only had to define the specific SDA and SCL pins to make this work
thanks!
richonguzman:
9600 baud rate?
The RAK12500 GPS module should be powered by the 3.3V VCC pin from the RAK4631. It does not require a special pin, as it draws power directly from the board.
