Hi @cipy,
I suggest you check your device’s sleep mode. When your device goes to sleep and wakes up the GPS should be updated and this is the reason why it takes so long (about 100-120s) to read the GPS data. If you set your sleep mode to 0 it will take about 30s for the GPS data to be read.
Hi @cipy,
In this command at+set_config=lora:send_interval:X: Y, x can take 3 positions (0,1 and 2) and each of them determinates the work mode of the node. For example, if you choose 0 your node won’t send data, if you choose 1 your node will send data and sleep for Y seconds and if you choose 2 it will send data without sleep.
Hi @nmcc,
You are right, we haven’t documented this yet because we are still working on the new doc center.
As soon as we get it ready everything will be there.
