I have a Wisblock Rak5005-0 with a WicBlock GNSS Location Module, 3-axis acceleration sensor and a light sensor (this is not used here soI might just take if off)
I’ve uploaded the GPS_Tracker example that I have customized by adding my own nodeDeviceEUI[8] and nodeAppKey[16] values as show in the ChirpStack Device configuration dashboard.
While the WisBlock is still connected to my PC I can see such data in the Arduno’s Serial Port monitor:
11:06:01.681 → check acc!
11:06:01.681 → X = 252.20mg Y = -5.00mg Z =992.81mg
11:06:11.689 → check acc!
11:06:11.689 → X = 255.21mg Y = -6.00mg Z =996.81mg
11:06:21.697 → check acc!
11:06:21.697 → X = 255.21mg Y = -5.00mg Z =1000.81mg
11:06:31.705 → check acc!
11:06:31.705 → X = 254.21mg Y = -10.01mg Z =993.81mg
11:06:41.668 → check acc!
11:06:41.668 → X = 251.20mg Y = -5.00mg Z =992.81mg
11:06:51.677 → check acc!
11:06:51.677 → X = 252.20mg Y = -4.00mg Z =995.81mg
but nothing in the “Device Data” tab on the ChirpStack.
The only thing I was able to notice was that I did receive the following in the “Lorawan Frames” tab:
First, I see the Join Accept, so all is good with the EUI’s and Keys.
There is a check in the example code that is only sending data if the device is in a specific orientation:
if( abs(x-z) < 400)
It is in the function void tx_lora_periodic_handler(void).
If you comment out that line, the device will send data independent of the orientation of the device.
Other option is to (if I remember correct) to change the orientation of the WisBlock so that the USB port is pointing up.
On the other hand, can you please show me what exactly needs to be done in order to get the DecodeDataHex to the objectJSON values? How exactly is the Decode function built? I’m not familiar with javascript but I can understand almost anything as I do some python programming myself.
And what about this type of 3-axis data? 11:06:51.677 → X = 252.20mg Y = -4.00mg Z =995.81mg Why this was not sent?
I have to apologize, just found out that the example that comes with the RAK-nRF52-Arduino was not updated. The old example was sending the location as a string and it was very difficult to parse it on the LNS side.
Please use the updated example GPS_Tracker.ino from our WisBlock repo.
The packet sent by this updated example can be decoded with the Javascript I sent you.
Regarding the values from the accelerometer, they are not included in the packet.
Sorry for the inconvenience with the old example code. We will update it in the next release of the BSP.
I have used the code you mentioned here GPS_Tracker.ino and only modified the uint8_t nodeDeviceEUI[8], uint8_t nodeAppEUI[8] and uint8_t nodeAppKey[16] values from my previous code and now I do get this into the Serial Monitor window:
10:22:37.771 → =====================================
10:22:37.771 → Welcome to RAK4630 LoRaWan!!!
10:22:37.771 → Type: OTAA
10:22:37.771 → Region: EU868
10:22:37.771 → Sensor at 0x18 started.
10:22:39.969 → gps uart init ok!
10:22:45.207 → OTAA Mode, Network Joined!
10:22:56.187 → check acc!
10:22:56.187 → X = 48.04mg Y = 16.01mg Z =1008.82mg
10:23:06.184 → check acc!
10:23:06.184 → X = 48.04mg Y = 16.01mg Z =1008.82mg
10:23:16.186 → check acc!
10:23:16.186 → X = 32.03mg Y = 32.03mg Z =1024.83mg
but nothing in the Device Data or Lorawan Frames tabs from the ChirpStack dashboard.
The codec used is still the one you exposed above:
function Decode(fPort, bytes, variables) {
// Decode an uplink message from a buffer
// (array) of bytes to an object of fields.
var decoded = {};
if (bytes[0] == 0x09) {
// GPS data
decoded.latitude = (bytes[4] | bytes[3] << 8 | bytes[2] << 16 | bytes[1] << 24 | (bytes[1] & 0x80 ? 0xFF << 24 : 0)) / 100000.0;
decoded.longitude = (bytes[9] | bytes[8] << 8 | bytes[7] << 16 | bytes[6] << 24 | (bytes[6] & 0x80 ? 0xFF << 24 : 0)) / 100000.0;
decoded.e_w = bytes[5];
decoded.n_s = bytes[10];
return decoded;
So bottom line, if with the earlier code I was only getting the Longitude, now I’m not getting anything.
Update: Just double-checked and indeed with the earlier code, same settings I am getting data without Longitude as described in my earlier post.
@digib
And in addition, you need to be outside. The GNSS antenna cannot get a location inside the house.
If the code doesn’t have a location, it does not send the packet.
Just tried the code and put the WisBlock into my frontyard. Getting this output from the encoder:
Found a mistake in the encoder, here is the corrected one, that gives the correct N/S/E/W data.
var decoded = {};
// GPS data
decoded.n_s = String.fromCharCode(bytes[5]);
decoded.e_w = String.fromCharCode(bytes[10]);
return decoded;
* @file GPS_Tracker.ino
* @author rakwireless.com
* @brief This sketch demonstrate a GPS tracker that collect location from a uBlox M7 GNSS sensor
* and send the data to lora gateway.
* It uses a 3-axis acceleration sensor to detect movement of the tracker
* @version 0.2
* @date 2021-04-30
* @copyright Copyright (c) 2020
* @note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
#include "SparkFunLIS3DH.h" //http://librarymanager/All#SparkFun-LIS3DH
#include "Wire.h"
#include <TinyGPS.h> //http://librarymanager/All#TinyGPS
LIS3DH SensorTwo(I2C_MODE, 0x18);
TinyGPS gps;
String tmp_data = "";
int direction_S_N = 0; //0--S, 1--N
int direction_E_W = 0; //0--E, 1--W
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_0 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t gCurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t gCurrentRegion = LORAMAC_REGION_EU868; /* Region:EU868*/
lmh_confirm gCurrentConfirm = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0x8A, 0xF3, 0xA6, 0xA8, 0xD1, 0x9F, 0xDF, 0x35};
uint8_t nodeAppEUI[8] = {0x00, 0x00, 0x00, 0x0, 0x00, 0x00, 0x00, 0x00};
uint8_t nodeAppKey[16] = {0xA1, 0x2C, 0xCB, 0x9C, 0x80, 0xAA, 0x5B, 0x6D, 0xC7, 0x62, 0x4E, 0x86, 0xA2, 0x71, 0xD5, 0x98};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_INTERVAL 10000 /**< Defines for user timer, the application data transmission interval. 10s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
pinMode(LED_BUILTIN, OUTPUT);
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
// Initialize LoRa chip.
lora_rak4630_init();
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (gCurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_CN779:
Serial.println("Region: CN779");
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
case LORAMAC_REGION_RU864:
Serial.println("Region: RU864");
break;
case LORAMAC_REGION_AS923_2:
Serial.println("Region: AS923-2");
break;
case LORAMAC_REGION_AS923_3:
Serial.println("Region: AS923-3");
break;
case LORAMAC_REGION_AS923_4:
Serial.println("Region: AS923-4");
break;
//lis3dh init
if (SensorTwo.begin() != 0)
Serial.println("Problem starting the sensor at 0x18.");
else
Serial.println("Sensor at 0x18 started.");
// Set low power mode
uint8_t data_to_write = 0;
SensorTwo.readRegister(&data_to_write, LIS3DH_CTRL_REG1);
data_to_write |= 0x08;
SensorTwo.writeRegister(LIS3DH_CTRL_REG1, data_to_write);
delay(100);
data_to_write = 0;
SensorTwo.readRegister(&data_to_write, 0x1E);
data_to_write |= 0x90;
SensorTwo.writeRegister(0x1E, data_to_write);
delay(100);
//gps init
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, 0);
delay(1000);
digitalWrite(WB_IO2, 1);
delay(1000);
Serial1.begin(9600);
while (!Serial1);
Serial.println("gps uart init ok!");
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&lora_callbacks, lora_param_init, doOTAA, gCurrentClass, gCurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
void loop()
// Put your application tasks here, like reading of sensors,
// Controlling actuators and/or other functions.
/**@brief LoRa function for handling HasJoined event.
if(doOTAA == true)
else
Serial.println("ABP Mode");
lmh_error_status ret = lmh_class_request(gCurrentClass);
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
* @param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, gCurrentConfirm);
//Not joined, try again later
return;
lmh_error_status error = lmh_send(&m_lora_app_data, gCurrentConfirm);
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for analytical direction.
void direction_parse(String tmp)
if (tmp.indexOf(",E,") != -1)
direction_E_W = 0;
else
direction_E_W = 1;
if (tmp.indexOf(",S,") != -1)
direction_S_N = 0;
else
direction_S_N = 1;
/**@brief Function for handling a LoRa tx timer timeout event.
String data = "";
float x = 0;
float y = 0;
float z = 0;
bool newData = false;
Serial.println("check acc!");
x = SensorTwo.readFloatAccelX() * 1000;
y = SensorTwo.readFloatAccelY() * 1000;
z = SensorTwo.readFloatAccelZ() * 1000;
data = "X = " + String(x) + "mg" + " Y = " + String(y) + "mg" + " Z =" + String(z) + "mg";
Serial.println(data);
data = "";
// if( abs(x-z) < 400)
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial1.available())
char c = Serial1.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
tmp_data += c;
if (gps.encode(c))// Did a new valid sentence come in?
newData = true;
direction_parse(tmp_data);
tmp_data = "";
float flat, flon;
int32_t ilat, ilon;
if (newData)
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat;
ilat = flat * 100000;
flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon;
ilon = flon * 100000;
m_lora_app_data.buffer[0] = 0x09;
//lat data
m_lora_app_data.buffer[1] = (ilat & 0xFF000000) >> 24;
m_lora_app_data.buffer[2] = (ilat & 0x00FF0000) >> 16;
m_lora_app_data.buffer[3] = (ilat & 0x0000FF00) >> 8;
m_lora_app_data.buffer[4] = ilat & 0x000000FF;
if(direction_S_N == 0)
m_lora_app_data.buffer[5] = 'S';
else
m_lora_app_data.buffer[5] = 'N';
//lon data
m_lora_app_data.buffer[6] = (ilon & 0xFF000000) >> 24;
m_lora_app_data.buffer[7] = (ilon & 0x00FF0000) >> 16;
m_lora_app_data.buffer[8] = (ilon & 0x0000FF00) >> 8;
m_lora_app_data.buffer[9] = ilon & 0x000000FF;
if(direction_E_W == 0)
m_lora_app_data.buffer[10] = 'E';
else
m_lora_app_data.buffer[10] = 'W';
m_lora_app_data.buffsize = 11;
send_lora_frame();
else
// else
// TimerSetValue(&appTimer, LORAWAN_APP_INTERVAL);
// TimerStart(&appTimer);
* @details Initializes the timer module. This creates and starts application timers.
return 0;
My codec is this one:
var decoded = {};
// GPS data
return decoded;
All the other configs are the same as the initial.
As noted earlier, if I use the previous code (from Arduino - Examples - WisBlock Examples … ) I am getting data but without the Longitude whenever I use the sensor indoor or outdoor while keeping your latest Decode function.
Moreover, I guess it should be a great addition to also output the GPS coordinates into the Serial Monitor just to verify that it is indeed getting GPS data.
