Issue: I’m setting up a Helium Data-Only-Hotspot with a RPi2 + RAK2245, following the instructions here: Data Only Hotspot Setup with RAK Concentrator + Raspberry Pi | Helium Documentation
I can successfully send data from a test sensor and it appears in the helium console, however I’m not seeing any other traffic (i.e. other than mine) going through my hotspot. I also see a lot of entries like this in syslog:
“helium_gateway[417]: ignoring push_data: Decode(LoraWan(InvalidPacketType(7))), module: gateway”
Other Helium hotspots in my area seem to transmit a decent volume of traffic and I have a good placement of an outdoor antenna. I’m thinking something is not configured correctly.
Setup: RPi2 (latest Raspbian OS Lite, upgraded) + RAK2245 (latest rak_common_for_gateway)
Server: Helium
Log:
Dec 19 20:30:49 rak-gateway helium_gateway[417]: uplink 737771588 us, 867.30 MHz, Ok(DataRate(SF12, BW125)), snr: -13.2, rssi: -118, len: 13 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:30:52 rak-gateway helium_gateway[417]: ignoring push_data: Decode(LoraWan(InvalidPacketType(7))), module: gateway
Dec 19 20:30:59 rak-gateway helium_gateway[417]: uplink 748042036 us, 868.50 MHz, Ok(DataRate(SF12, BW125)), snr: -17.5, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:31:41 rak-gateway helium_gateway[417]: uplink 789875572 us, 868.30 MHz, Ok(DataRate(SF8, BW125)), snr: -11, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:31:56 rak-gateway helium_gateway[417]: ignoring push_data: Decode(LoraWan(InvalidPacketType(7))), module: gateway
Dec 19 20:33:05 rak-gateway helium_gateway[417]: uplink 874014587 us, 868.50 MHz, Ok(DataRate(SF7, BW125)), snr: -3, rssi: -115, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:08 rak-gateway helium_gateway[417]: uplink 876662644 us, 868.30 MHz, Ok(DataRate(SF8, BW125)), snr: -10.2, rssi: -118, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:11 rak-gateway helium_gateway[417]: uplink 880409868 us, 867.70 MHz, Ok(DataRate(SF12, BW125)), snr: -8, rssi: -118, len: 32 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:13 rak-gateway helium_gateway[417]: uplink 882218299 us, 868.50 MHz, Ok(DataRate(SF7, BW125)), snr: -3.5, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:21 rak-gateway helium_gateway[417]: uplink 890473092 us, 868.50 MHz, Ok(DataRate(SF8, BW125)), snr: -4, rssi: -114, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:34 rak-gateway helium_gateway[417]: ignoring push_data: Decode(LoraWan(InvalidPacketType(7))), module: gateway
Dec 19 20:33:38 rak-gateway helium_gateway[417]: uplink 906894211 us, 868.30 MHz, Ok(DataRate(SF7, BW125)), snr: -2.2, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:39 rak-gateway helium_gateway[417]: uplink 907875740 us, 867.90 MHz, Ok(DataRate(SF9, BW125)), snr: -9.8, rssi: -119, len: 21 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:33:51 rak-gateway helium_gateway[417]: no update found, module: updater
Dec 19 20:33:52 rak-gateway helium_gateway[417]: uplink 921279211 us, 868.30 MHz, Ok(DataRate(SF7, BW125)), snr: -2.5, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
Dec 19 20:34:07 rak-gateway helium_gateway[417]: uplink 935718251 us, 868.50 MHz, Ok(DataRate(SF7, BW125)), snr: -3.5, rssi: -117, len: 23 from MacAddress(B8:27:EB:FF:FE:16:A2), module: gateway
