i did buy two kits
1- Helium Developer Kit | Support Helium Regions EU868, AU915, US915, AS923
2- Helium Mapper Kit | Helium Mapper Kit 1 / US915
after an intensive search, I still don’t know how to figure it out flash those boards or make the helium mapper.
i did follow the instructions to add the mapper to the console and I did, . actually, I added all three boards. since the developer kit includes 2 boards of RAK-5005-0 V1.
on youtube there is none, nobody documented or did a video on how to create one for the mapper.
so I need the community’s help here. to make one.
Please I would appreciate your input on this matter!
Even most guides and tutorials focus on LoRaWan servers like TTN or Chirpstack, they work the same with the Helium Console (which is just another LoRaWan server)
Hello Bernd, im so lucky that you are the one who did answer me
I actually did follow your bootloader instruction for windows and it did work. i actually did that for all three boards.
but the link you sent me yes it shows the instructions to use only VS/ PlatformIO which I’m not that expert or even close to having the min knowledge.
but where I can put the 3 Device EUI msb , App EUI msb & App Key msb.
i seen something using arduino.exe and changing the values on that programming tool to the actual ones we take from console.helium.com
The way Helium Mapper code is written is quite different from the examples in the WisBlock repo.
The concept is that the DevEUI, AppEUI and AppKey are not inside the code. Instead you use a terminal program or a BLE app on a phone to setup these credentials. That way you can use the same compiled code on many devices.
If you want to compile the Helium Mapper code in Arduino instead of PlatformIO, that is not a big problem.
Create a folder named Helium-Mapper
Copy the files from the src folder into the Helium Mapper folder.
Hello Bernd,
i didnt have the chance to continue finishing up the mapper project due to welcoming a new baby to the family!
thankg God she arrived and I’m back to business!
can you please explain to me how to use a terminal program or a BLE app on iPhone!
app store lack of those goodies like google store!. if there is no other way, i will buy an android tablet not a big deal!.
also one question about the RAK5005 v.1 board. is there a way we can flash it, i cant see it anymore on Bluetooth devices. even i reset it?
I have a GNSS tracker code that can be switched between different formats, but I didn’t share it yet on Github.
It supports CayenneLPP, extended precision LPP, Helium Mapper format and LoRaWAN Field Tester packet formats.
Maybe time to release it to the open source.
EDIT
It should be **beegee-tokyo/[email protected]** without the apostroph
RAK10701-H (Field Mapper for Helium) stopped connecting to the Helium. Field tester is within gateway range but it fails to connect. Used to work before. What could be the reason?
Looks like everything is wrong in the decoded output.
I don’t think you are living 31km above the earth, or do you?
I think the problem here is that your Helium Mapper is not sending the correct payload. Looking on the payload I think that is a CayenneLPP decoded payload, not the “special” Helium Mapper payload.
