Issue: I have downloaded the latest chirpstack v4 and configured it to use RAK2287 concentrator, but it appears to be failing to start the concentrator
Setup: Helium Rak V2 running Chirpstack V4
Server:
Details:
The log shows this routine over and over again, I suspect that the pin numbering is slightly different to the usual Pi Hat.
Triggering sx1302 reset
Setting i2c device path, path: /dev/i2c-1
Setting board configuration, lorawan_public: true, clock_source: 0
Setting up fine timestamp, enable: false
Setting up concentrator channels
Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1250
Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1250
Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Starting the concentrator
Configuring reset pin, dev: /dev/gpiochip0, pin: 17
Starting Concentratord SX1302 (version: 4.2.0-test.2, docs: Introduction - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server)
