- What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
RAK 4331
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
RUI3 -
What firmware version? Can it be obtained with AT+VER=?
AT+VER=RUI_4.1.1_RAK4631 -
Computer OS? (MacOS, Linux, Windows)
Windows -
What Computer OS version?
11
- How often does the problem happen?
I want to modify AT custom parameters from downlink messages, I followed an example but the code remains checked and does not execute the AT+SENDINT command.
How can we replicate the problem?
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
type or paste c/**
* @file RUI3-Modular.ino
* @author Bernd Giesecke ([email protected])
* @brief RUI3 based code for low power practice
* @version 0.1
* @date 2023-03-29
* @copyright Copyright (c) 2023
#include "app.h"
/** Packet is confirmed/unconfirmed (Set with AT commands) */
bool g_confirmed_mode = false;
/** If confirmed packet, number or retries (Set with AT commands) */
uint8_t g_confirmed_retry = 0;
/** Data rate (Set with AT commands) */
uint8_t g_data_rate = 3;
/** Flag if transmit is active, used by some sensors */
volatile bool tx_active = false;
/** fPort to send packages */
uint8_t set_fPort = 2;
/** Payload buffer */
WisCayenne g_solution_data(255);
uint32_t g_send_repeat_time = 0;
/** Flag if RAK1901 was found */
bool has_rak1901 = false;
/** Flag if RAK1902 was found */
bool has_rak1902 = false;
* @brief Callback after join request cycle
* @param status Join result
if (status != 0)
MYLOG("JOIN-CB", "LoRaWan OTAA - join fail! \r\n");
// To be checked if this makes sense
// api.lorawan.join();
else
MYLOG("JOIN-CB", "LoRaWan OTAA - joined! \r\n");
digitalWrite(LED_BLUE, LOW);
* @brief LoRaWAN callback after packet was received
* @param data pointer to structure with the received data
void receiveCallback(SERVICE_LORA_RECEIVE_T *data)
MYLOG("RX-CB", "RX, port %d, DR %d, RSSI %d, SNR %d", data->Port, data->RxDatarate, data->Rssi, data->Snr);
for (int i = 0; i < data->BufferSize; i++)
Serial.printf("%02X", data->Buffer[i]);
Serial.print("\r\n");
tx_active = false;
// Parse the incoming command
switch (data->Buffer[0])
// Change send interval (custom AT command)
case 0x41:
uint32_t new_value = 0;
new_value |= data->Buffer[1] << 0;
new_value |= data->Buffer[2] << 8;
new_value |= data->Buffer[3] << 16;
new_value |= data->Buffer[4] << 24;
save_and_set_sendfreq(new_value);
break;
// Change data rate (standard AT command)
case 0x02:
uint8_t new_value = data->Buffer[1];
api.lorawan.dr.set(new_value);
break;
// Other commands
default:
// Add additional cases for other commands if needed
break;
* @brief Handler for send frequency AT commands
* @param port Serial port used
* @param cmd char array with the received AT command
* @param param char array with the received AT command parameters
* @return int result of command parsing
* AT_OK AT command & parameters valid
* AT_PARAM_ERROR command or parameters invalid
int interval_send_handler1(SERIAL_PORT port, char *cmd, stParam *param)
if (param->argc == 1 && !strcmp(param->argv[0], "?"))
Serial.print(cmd);
Serial.printf("=%lds\r\n", g_send_repeat_time / 1000);
else if (param->argc == 1)
for (int i = 0; i < strlen(param->argv[0]); i++)
if (!isdigit(*(param->argv[0] + i)))
return AT_PARAM_ERROR;
uint32_t new_send_freq = strtoul(param->argv[0], NULL, 10);
g_send_repeat_time = new_send_freq * 1000;
save_and_set_sendfreq(g_send_repeat_time);
else
return AT_OK;
* @brief Save and set new send interval
* @param new_interval new interval time in milliseconds
void save_and_set_sendfreq(uint32_t new_interval)
// Stop the timer
api.system.timer.stop(RAK_TIMER_0);
if (g_send_repeat_time != 0)
// Restart the timer
api.system.timer.start(RAK_TIMER_0, g_send_repeat_time, NULL);
// Save custom settings
save_at_setting();
* @brief Callback for LinkCheck result
* @param data pointer to structure with the linkcheck result
void linkcheckCallback(SERVICE_LORA_LINKCHECK_T *data)
MYLOG("LC_CB", "%s Margin %d GW# %d RSSI%d SNR %d", data->State == 0 ? "Success" : "Failed",
data->DemodMargin, data->NbGateways,
* @brief LoRaWAN callback after TX is finished
* @param status TX status
MYLOG("TX-CB", "TX status %d", status);
tx_active = false;
* @brief LoRa P2P callback if a packet was received
* @param data pointer to the data with the received data
void recv_cb(rui_lora_p2p_recv_t data)
MYLOG("RX-P2P-CB", "P2P RX, RSSI %d, SNR %d", data.Rssi, data.Snr);
for (int i = 0; i < data.BufferSize; i++)
Serial.printf("%02X", data.Buffer[i]);
tx_active = false;
* @brief LoRa P2P callback if a packet was sent
void send_cb(void)
MYLOG("TX-P2P-CB", "P2P TX finished");
tx_active = false;
* @brief LoRa P2P callback for CAD result
* @param result true if activity was detected, false if no activity was detected
void cad_cb(bool result)
MYLOG("CAD-P2P-CB", "P2P CAD reports %s", result ? "activity" : "no activity");
* @brief Arduino setup, called once after reboot/power-up
void setup()
// Setup for LoRaWAN
if (api.lorawan.nwm.get() == 1)
g_confirmed_mode = api.lorawan.cfm.get();
g_confirmed_retry = api.lorawan.rety.get();
g_data_rate = api.lorawan.dr.get();
// Setup the callbacks for joined and send finished
api.lorawan.registerRecvCallback(receiveCallback);
api.lorawan.registerLinkCheckCallback(linkcheckCallback);
else // Setup for LoRa P2P
api.lora.registerPRecvCallback(recv_cb);
api.lora.registerPSendCallback(send_cb);
api.lora.registerPSendCADCallback(cad_cb);
pinMode(LED_GREEN, OUTPUT);
digitalWrite(LED_GREEN, HIGH);
pinMode(LED_BLUE, OUTPUT);
digitalWrite(LED_BLUE, HIGH);
pinMode(WB_IO1, OUTPUT);
digitalWrite(WB_IO1, LOW);
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, LOW);
// Start Serial
// Delay for 5 seconds to give the chance for AT+BOOT
delay(5000);
api.system.firmwareVersion.set("RUI3-T_H_P-V1.0.0");
Serial.println("RAKwireless RUI3 Node");
Serial.println("Setup the device with WisToolBox or AT commands before using it");
Serial.printf("Version %s\n", api.system.firmwareVersion.get().c_str());
// Initialize module
Wire.begin();
// Register the custom AT command to get device status
if (!init_status_at())
MYLOG("SETUP", "Add custom AT command STATUS fail");
// Register the custom AT command to set the send interval
if (!init_interval_at())
MYLOG("SETUP", "Add custom AT command Send Interval fail");
// Get saved sending interval from flash
get_at_setting();
digitalWrite(LED_GREEN, LOW);
// Create a timer.
api.system.timer.create(RAK_TIMER_0, sensor_handler, RAK_TIMER_PERIODIC);
if (custom_parameters.send_interval != 0)
// Start a timer.
api.system.timer.start(RAK_TIMER_0, custom_parameters.send_interval, NULL);
// Check if it is LoRa P2P
if (api.lorawan.nwm.get() == 0)
sensor_handler(NULL);
if (g_confirmed_mode)
MYLOG("SETUP", "Confirmed enabled");
else
MYLOG("SETUP", "Confirmed disabled");
MYLOG("SETUP", "Retry = %d", g_confirmed_retry);
MYLOG("SETUP", "DR = %d", g_data_rate);
// Enable low power mode
api.system.lpm.set(1);
// If available, enable BLE advertising for 30 seconds and open the BLE UART channel
#if defined(_VARIANT_RAK3172_) || defined(_VARIANT_RAK3172_SIP_)
// No BLE
#else
Serial6.begin(115200, RAK_AT_MODE);
api.ble.advertise.start(30);
#endif
// Check if sensors are connected and initialize them
has_rak1901 = init_rak1901();
if (has_rak1901)
Serial.println("+EVT:RAK1901");
* @brief sensor_handler is a timer function called every
* custom_parameters.send_interval milliseconds. Default is 120000. Can be
* changed with ATC+SENDINT command
void sensor_handler(void *)
MYLOG("UPLINK", "Start");
// Check if the node has joined the network
if (!api.lorawan.njs.get())
MYLOG("UPLINK", "Not joined, skip sending");
return;
// Clear payload
g_solution_data.reset();
// Get sensor values
if (has_rak1901)
read_rak1901();
float battery_reading = 0.0;
// Add battery voltage
for (int i = 0; i < 10; i++)
battery_reading += api.system.bat.get(); // get battery voltage
battery_reading = battery_reading / 10;
g_solution_data.addVoltage(1, battery_reading);
// Send the packet
send_packet();
* @brief This example is complete timer driven.
* The loop() does nothing than sleep.
void loop()
api.system.sleep.all();
* @brief Send the data packet that was prepared in
* Cayenne LPP format by the different sensor and location
* aqcuision functions
void send_packet(void)
// Check if it is LoRaWAN
MYLOG("UPLINK", "Sending packet over LoRaWAN");
// Send the packet
if (api.lorawan.send(g_solution_data.getSize(), g_solution_data.getBuffer(), set_fPort, g_confirmed_mode, g_confirmed_retry))
MYLOG("UPLINK", "Packet enqueued, size %d", g_solution_data.getSize());
tx_active = true;
else
MYLOG("UPLINK", "Send failed");
tx_active = false;
// It is P2P
else
MYLOG("UPLINK", "Send packet with size %d over P2P", g_solution_data.getSize());
if (api.lora.psend(g_solution_data.getSize(), g_solution_data.getBuffer(), true))
MYLOG("UPLINK", "Packet enqueued");
else
ode here
