I am working with a RAK4630 module paired with an RAK5860, and I am trying to control the power state of the RAK5860 module using the WIS_PWRKEY as mentioned in the documentation. I believe that WIS_PWRKEY is connected to pin 29, but I am unsure if this is correct or if I am implementing the control sequence properly.
Here’s the code snippet I’ve been testing:
#include <Wire.h>
#include <Adafruit_TinyUSB.h>
#include "Arduino.h"
#define WIS_PWRKEY_PIN 29 // Assuming pin 29 is the WIS_PWRKEY
void setup() {
pinMode(WIS_PWRKEY_PIN, OUTPUT);
void loop() {
// Turn on the module
digitalWrite(WIS_PWRKEY_PIN, HIGH);
delay(1000); // High for 1 second to turn on
digitalWrite(WIS_PWRKEY_PIN, LOW);
delay(15000); // Wait for 15 seconds
// Turn off the module
delay(1500); // High for 1.5 seconds to turn off
delay(15000); // Wait for 15 seconds before toggling the power again
I’m attempting to toggle the power state of the RAK5860 every 15 seconds using the above code. Can anyone confirm if pin 29 is indeed the correct pin for WIS_PWRKEY on the RAK5860, or should I be using a different pin? Any guidance or corrections on my code would also be greatly appreciated.
Thank you!
