Ok, Thanks for the confirmation.
Dec 19 15:45:17 rak-gateway : # PULL_DATA sent: 3 (100.00% acknowledged)
Dec 19 15:45:17 rak-gateway : # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Dec 19 15:45:17 rak-gateway : # RF packets sent to concentrator: 0 (0 bytes)
Dec 19 15:45:17 rak-gateway : # TX errors: 0
Dec 19 15:45:17 rak-gateway : # TX rejected (collision packet): 0.00% (req:3324, rej:0)
Dec 19 15:45:17 rak-gateway : # TX rejected (collision beacon): 0.00% (req:3324, rej:0)
Dec 19 15:45:17 rak-gateway : # TX rejected (too late): 0.03% (req:3324, rej:1)
Dec 19 15:45:17 rak-gateway : # TX rejected (too early): 0.27% (req:3324, rej:9)
Dec 19 15:45:17 rak-gateway : # BEACON queued: 0
Dec 19 15:45:17 rak-gateway : # BEACON sent so far: 0
Dec 19 15:45:17 rak-gateway : # BEACON rejected: 0
Dec 19 15:45:17 rak-gateway : ### [JIT] ###
Dec 19 15:45:17 rak-gateway : # SX1301 time (PPS): 3897795113
Dec 19 15:45:17 rak-gateway : src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Dec 19 15:45:17 rak-gateway : ### [GPS] ###
Dec 19 15:45:17 rak-gateway : # Valid time reference (age: 0 sec)
Dec 19 15:45:17 rak-gateway : # GPS coordinates: latitude 12.95217, longitude 80.17129, altitude 38 m
Dec 19 15:45:17 rak-gateway : ##### END #####
Dec 19 15:45:17 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:15:02 GMT”,“lati”:12.95217,“long”:80.17129,“alti”:38,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
Dec 19 15:45:17 rak-gateway : INFO: Received pkt from mote: 260118A6 (fcnt=250)
Dec 19 15:45:17 rak-gateway : JSON up: {“rxpk”:[{“tmst”:3899578628,“time”:“2019-12-19T10:15:02.783515Z”,“tmms”:1260785721783,“chan”:1,“rfch”:0,“freq”:865.402500,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:9.8,“rssi”:-40,“size”:46,“data”:“gKYYASaA+gAK2WqKC4a39EnBbSXJzLXlOP3BCzih32u7jcXLS3PnvpquiVAMzw==”}]}
Dec 19 15:45:17 rak-gateway : INFO: [down] PULL_ACK received in 392 ms
Dec 19 15:45:17 rak-gateway : JSON up: {“rxpk”:[{“tmst”:3903924212,“time”:“2019-12-19T10:15:07.129098Z”,“tmms”:1260785726129,“chan”:1,“rfch”:0,“freq”:865.402500,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“lsnr”:9.5,“rssi”:-39,“size”:46,“data”:“gKYYASaA+gAK2WqKC4a39EnBbSXJzLXlOP3BCzih32u7jcXLS3PnvpquiVAMzw==”}]}
Dec 19 15:45:17 rak-gateway : INFO: [down] PULL_ACK received in 400 ms
Dec 19 15:45:17 rak-gateway : INFO: Received pkt from mote: 26041F46 (fcnt=24)
Dec 19 15:45:17 rak-gateway : JSON up: {“rxpk”:[{“tmst”:3912250499,“time”:“2019-12-19T10:15:15.455386Z”,“tmms”:1260785734455,“chan”:0,“rfch”:0,“freq”:865.062500,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:9.5,“rssi”:-84,“size”:148,“data”:“QEYfBCaAGAABAtTytxWTeyut96MXHeH00szTmbYP6vJXnSUTId/G2RqkWbMTRTfFElWSmlRpHrvcAqiTirrcv8lrab/J3LAvG5fvsZzAwFwpNJ9XjvatS0vv8wDhpCFSdcltPuUXHMLax2FvD8FDhIfG3jqK4OhItzGRDLG/LtDt3wvyHJLGlrWO0/6tSO4xsYt27g==”}]}
Dec 19 15:45:17 rak-gateway : INFO: [down] PULL_RESP received - token[142:112]
Dec 19 15:46:36 rak-gateway : JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:27,“ant”:0,“brd”:0,“tmst”:3913250499,“freq”:865.0625,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“ipol”:true,“size”:17,“data”:“YEYfBCaFD2UDAAcAAaTBBhY=”}}
Dec 19 15:46:36 rak-gateway : INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Dec 19 15:46:36 rak-gateway : INFO: [down] PULL_ACK received in 399 ms
Dec 19 15:46:36 rak-gateway : ##### 2019-12-19 10:15:32 GMT #####
Dec 19 15:46:36 rak-gateway : ### [UPSTREAM] ###
Dec 19 15:46:36 rak-gateway : # RF packets received by concentrator: 3
Dec 19 15:46:36 rak-gateway : # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Dec 19 15:46:36 rak-gateway : # RF packets forwarded: 3 (240 bytes)
Dec 19 15:46:36 rak-gateway : # PUSH_DATA datagrams sent: 4 (1180 bytes)
Dec 19 15:46:36 rak-gateway : # PUSH_DATA acknowledged: 0.00%
Dec 19 15:46:36 rak-gateway : ### [DOWNSTREAM] ###
Dec 19 15:46:36 rak-gateway : # PULL_DATA sent: 3 (100.00% acknowledged)
Dec 19 15:46:36 rak-gateway : # PULL_RESP(onse) datagrams received: 1 (197 bytes)
Dec 19 15:46:36 rak-gateway : # RF packets sent to concentrator: 1 (17 bytes)
Dec 19 15:46:36 rak-gateway : # TX errors: 0
Dec 19 15:46:36 rak-gateway : # TX rejected (collision packet): 0.00% (req:3325, rej:0)
Dec 19 15:46:36 rak-gateway : # TX rejected (collision beacon): 0.00% (req:3325, rej:0)
Dec 19 15:46:36 rak-gateway : # TX rejected (too late): 0.03% (req:3325, rej:1)
Dec 19 15:46:36 rak-gateway : # TX rejected (too early): 0.27% (req:3325, rej:9)
Dec 19 15:46:36 rak-gateway : # BEACON queued: 0
Dec 19 15:46:36 rak-gateway : # BEACON sent so far: 0
Dec 19 15:46:36 rak-gateway : # BEACON rejected: 0
Dec 19 15:46:36 rak-gateway : ### [JIT] ###
Dec 19 15:46:36 rak-gateway : # SX1301 time (PPS): 3927795114
Dec 19 15:46:36 rak-gateway : src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Dec 19 15:46:36 rak-gateway : ### [GPS] ###
Dec 19 15:46:36 rak-gateway : # Valid time reference (age: 0 sec)
Dec 19 15:46:36 rak-gateway : # GPS coordinates: latitude 12.95222, longitude 80.17137, altitude 32 m
Dec 19 15:46:36 rak-gateway : ##### END #####
Dec 19 15:46:36 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:15:32 GMT”,“lati”:12.95222,“long”:80.17137,“alti”:32,“rxnb”:3,“rxok”:3,“rxfw”:3,“ackr”:0.0,“dwnb”:1,“txnb”:1}}
Dec 19 15:46:36 rak-gateway : INFO: [down] PULL_ACK received in 394 ms
Dec 19 15:46:36 rak-gateway : INFO: [down] PULL_ACK received in 392 ms
Dec 19 15:46:36 rak-gateway : INFO: Disabling GPS mode for concentrator’s counter…
Dec 19 15:46:36 rak-gateway : INFO: host/sx1301 time offset=(1576746604s:160280µs) - drift=-476µs
Dec 19 15:46:36 rak-gateway : INFO: Enabling GPS mode for concentrator’s counter.
Dec 19 15:46:36 rak-gateway : ##### 2019-12-19 10:16:02 GMT #####
Dec 19 15:46:36 rak-gateway : # RF packets received by concentrator: 0
Dec 19 15:46:36 rak-gateway : # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Dec 19 15:46:36 rak-gateway : # RF packets forwarded: 0 (0 bytes)
Dec 19 15:46:36 rak-gateway : # PUSH_DATA datagrams sent: 1 (153 bytes)
Dec 19 15:46:36 rak-gateway : # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Dec 19 15:46:36 rak-gateway : # RF packets sent to concentrator: 0 (0 bytes)
Dec 19 15:46:36 rak-gateway : # SX1301 time (PPS): 3957795116
Dec 19 15:46:36 rak-gateway : # GPS coordinates: latitude 12.95221, longitude 80.17135, altitude 24 m
Dec 19 15:46:36 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:16:02 GMT”,“lati”:12.95221,“long”:80.17135,“alti”:24,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
Dec 19 15:46:36 rak-gateway : INFO: [down] PULL_ACK received in 393 ms
Dec 19 15:46:37 rak-gateway : INFO: [down] PULL_ACK received in 403 ms
Dec 19 15:46:37 rak-gateway : ##### 2019-12-19 10:16:32 GMT #####
Dec 19 15:46:37 rak-gateway : ### [UPSTREAM] ###
Dec 19 15:46:37 rak-gateway : # RF packets received by concentrator: 0
Dec 19 15:46:37 rak-gateway : # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Dec 19 15:46:37 rak-gateway : # RF packets forwarded: 0 (0 bytes)
Dec 19 15:46:37 rak-gateway : # PUSH_DATA datagrams sent: 1 (153 bytes)
Dec 19 15:46:37 rak-gateway : # PUSH_DATA acknowledged: 0.00%
Dec 19 15:46:37 rak-gateway : ### [DOWNSTREAM] ###
Dec 19 15:46:37 rak-gateway : # PULL_DATA sent: 3 (100.00% acknowledged)
Dec 19 15:46:37 rak-gateway : # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Dec 19 15:46:37 rak-gateway : # RF packets sent to concentrator: 0 (0 bytes)
Dec 19 15:46:37 rak-gateway : # TX errors: 0
Dec 19 15:46:37 rak-gateway : # TX rejected (collision packet): 0.00% (req:3325, rej:0)
Dec 19 15:46:37 rak-gateway : # TX rejected (collision beacon): 0.00% (req:3325, rej:0)
Dec 19 15:46:37 rak-gateway : # TX rejected (too late): 0.03% (req:3325, rej:1)
Dec 19 15:46:37 rak-gateway : # TX rejected (too early): 0.27% (req:3325, rej:9)
Dec 19 15:46:37 rak-gateway : # BEACON queued: 0
Dec 19 15:46:37 rak-gateway : # BEACON sent so far: 0
Dec 19 15:46:37 rak-gateway : # BEACON rejected: 0
Dec 19 15:46:37 rak-gateway : ### [JIT] ###
Dec 19 15:46:37 rak-gateway : # SX1301 time (PPS): 3987795118
Dec 19 15:46:37 rak-gateway : src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Dec 19 15:46:37 rak-gateway : ### [GPS] ###
Dec 19 15:46:37 rak-gateway : # Valid time reference (age: 0 sec)
Dec 19 15:46:37 rak-gateway : # GPS coordinates: latitude 12.95225, longitude 80.17144, altitude 10 m
Dec 19 15:46:37 rak-gateway : ##### END #####
Dec 19 15:46:37 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:16:32 GMT”,“lati”:12.95225,“long”:80.17144,“alti”:10,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 399 ms
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 405 ms
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 393 ms
Dec 19 15:48:02 rak-gateway : INFO: Disabling GPS mode for concentrator’s counter…
Dec 19 15:48:02 rak-gateway : INFO: host/sx1301 time offset=(1576746604s:159806µs) - drift=-474µs
Dec 19 15:48:02 rak-gateway : INFO: Enabling GPS mode for concentrator’s counter.
Dec 19 15:48:02 rak-gateway : ##### 2019-12-19 10:17:02 GMT #####
Dec 19 15:48:02 rak-gateway : ### [UPSTREAM] ###
Dec 19 15:48:02 rak-gateway : # RF packets received by concentrator: 0
Dec 19 15:48:02 rak-gateway : # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Dec 19 15:48:02 rak-gateway : # RF packets forwarded: 0 (0 bytes)
Dec 19 15:48:02 rak-gateway : # PUSH_DATA datagrams sent: 1 (153 bytes)
Dec 19 15:48:02 rak-gateway : # PUSH_DATA acknowledged: 0.00%
Dec 19 15:48:02 rak-gateway : ### [DOWNSTREAM] ###
Dec 19 15:48:02 rak-gateway : # PULL_DATA sent: 3 (100.00% acknowledged)
Dec 19 15:48:02 rak-gateway : # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Dec 19 15:48:02 rak-gateway : # RF packets sent to concentrator: 0 (0 bytes)
Dec 19 15:48:02 rak-gateway : # TX errors: 0
Dec 19 15:48:02 rak-gateway : # TX rejected (collision packet): 0.00% (req:3325, rej:0)
Dec 19 15:48:02 rak-gateway : # TX rejected (collision beacon): 0.00% (req:3325, rej:0)
Dec 19 15:48:02 rak-gateway : # TX rejected (too late): 0.03% (req:3325, rej:1)
Dec 19 15:48:02 rak-gateway : # TX rejected (too early): 0.27% (req:3325, rej:9)
Dec 19 15:48:02 rak-gateway : # BEACON queued: 0
Dec 19 15:48:02 rak-gateway : # BEACON sent so far: 0
Dec 19 15:48:02 rak-gateway : # BEACON rejected: 0
Dec 19 15:48:02 rak-gateway : ### [JIT] ###
Dec 19 15:48:02 rak-gateway : # SX1301 time (PPS): 4017795120
Dec 19 15:48:02 rak-gateway : src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Dec 19 15:48:02 rak-gateway : ### [GPS] ###
Dec 19 15:48:02 rak-gateway : # Valid time reference (age: 0 sec)
Dec 19 15:48:02 rak-gateway : # GPS coordinates: latitude 12.95225, longitude 80.17147, altitude 11 m
Dec 19 15:48:02 rak-gateway : ##### END #####
Dec 19 15:48:02 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:17:02 GMT”,“lati”:12.95225,“long”:80.17147,“alti”:11,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 523 ms
Dec 19 15:48:02 rak-gateway : INFO: Received pkt from mote: 26041F46 (fcnt=25)
Dec 19 15:48:02 rak-gateway : JSON up: {“rxpk”:[{“tmst”:4034819763,“time”:“2019-12-19T10:17:18.024642Z”,“tmms”:1260785857024,“chan”:1,“rfch”:0,“freq”:865.402500,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:9.0,“rssi”:-82,“size”:148,“data”:“QEYfBCaAGQABz/edCUdP2JlxT4ahUUlhCrNOViC20ZvWnDgK+97rK5X2mp4ni7X+Rsan4am/dXd25ccR2ob7W3GUO1g0YLEV33aUgZrTz3nVcYUR5GZO7IqZxbn5k26FozQAuJkPpvdIY4yoo3Zt8B8ERtfcCr4EtICAxq7TVUbXXnkeakxqxZ/ewCSsIFxhXOPMoA==”}]}
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_RESP received - token[122:74]
Dec 19 15:48:02 rak-gateway : JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:27,“ant”:0,“brd”:0,“tmst”:4035819763,“freq”:865.4025,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“ipol”:true,“size”:17,“data”:“YEYfBCaFEGUDAAcAAV06Iz4=”}}
Dec 19 15:48:02 rak-gateway : INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 395 ms
Dec 19 15:48:02 rak-gateway : ##### 2019-12-19 10:17:32 GMT #####
Dec 19 15:48:02 rak-gateway : # RF packets received by concentrator: 1
Dec 19 15:48:02 rak-gateway : # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Dec 19 15:48:02 rak-gateway : # RF packets forwarded: 1 (148 bytes)
Dec 19 15:48:02 rak-gateway : # PUSH_DATA datagrams sent: 2 (586 bytes)
Dec 19 15:48:02 rak-gateway : # PULL_RESP(onse) datagrams received: 1 (197 bytes)
Dec 19 15:48:02 rak-gateway : # RF packets sent to concentrator: 1 (17 bytes)
Dec 19 15:48:02 rak-gateway : # TX rejected (collision packet): 0.00% (req:3326, rej:0)
Dec 19 15:48:02 rak-gateway : # TX rejected (collision beacon): 0.00% (req:3326, rej:0)
Dec 19 15:48:02 rak-gateway : # TX rejected (too late): 0.03% (req:3326, rej:1)
Dec 19 15:48:02 rak-gateway : # TX rejected (too early): 0.27% (req:3326, rej:9)
Dec 19 15:48:02 rak-gateway : # SX1301 time (PPS): 4047795122
Dec 19 15:48:02 rak-gateway : # GPS coordinates: latitude 12.95227, longitude 80.17150, altitude 6 m
Dec 19 15:48:02 rak-gateway : JSON up: {“stat”:{“time”:“2019-12-19 10:17:32 GMT”,“lati”:12.95227,“long”:80.17150,“alti”:6,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:0.0,“dwnb”:1,“txnb”:1}}
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 401 ms
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 394 ms
Dec 19 15:48:02 rak-gateway : INFO: [down] PULL_ACK received in 400 ms
Dec 19 15:48:02 rak-gateway : INFO: host/sx1301 time offset=(1576746604s:159335µs) - drift=-471µs
Dec 19 15:48:02 rak-gateway : ##### 2019-12-19 10:18:02 GMT #####
Dec 19 15:48:02 rak-gateway : # PUSH_DATA datagrams sent: 1 (152 bytes)
TIA.
