I have resetted my gateway.
redownloaded the rak7249 self extracting installer, I am using rak7258 gateway but since rak7258 is using rak7249 concentrator not sure if that affects anything.
is there anyone who has experience with loriot and gateway integration or @beegee, is there anyone that you know may be familiar with this topic?
Thank you very much for the help, really appreciate it
Is there anything i did wrong or did i use the wrong community server for loriot to use it as the network server?
Essentially I am using rak7258 as the gateway and I want to connect it as a gateway on ap1.loriot.io
I want to use the one in singapore which there is 2. ap1.loriot.io and ap4pro.loriot.io
I followed the documentation for rak7249 and used the rak7249 for on loriot as it has come to my attention that rak7258 is using rak7249 as the concentrator therefore I assume that it should be fine since the documentation for rak7258 also uses the rak7249 device on loriot. The only difference was the i substituted eu1.loriot.io to ap1.loriot.io(since it is a free community server for singapore region).
Since i followed the documentation exactly, I am not sure what the issue is.
Why don’t you use the right gateway type while adding the gateway at Loriot? You can choose “RAK 7258” type and follow the instructions. Works well for us.
i omitted:/etc/init.d/sx130x_lora_pkt_fwd disable; /etc/init.d/loriot-gw enable; reboot now
this disables the packet forwarder and enable loriot gateway did you change it to something like, /etc/init.d/sx130x_lora_pkt_fwd disable; /etc/init.d/loriot-gw enable; reboot now
We run a lot of Rak gateways with loriot, more recently Loriot have stopped development of their gateway integrations causing many hours of frustration!
So we have started connecting gateways to loriot with Basic Station, that all gateway support and it work well.
Class C downlinks where broken with the forwarder but has been fixed with a recent update.
