I’m trying to config the wifi radio channel for a specific channel instead of using the auto configuration mode. Suppose i changed it to channel 6, After a reset in the status it shows the current wifi radio channel is 1. Could someone help me to fix this issue please.
Will check this. Maybe a bug.
Hi again. I check with RAK7249 with latest FW (v198). And Wi-Fi channel set up works fine. Selected channel do not change after reboot. Please update to latest FW if you are not https://downloads.rakwireless.com/en/LoRa/DIY-Gateway-RAK7249/Firmware/
If problem persist please contact me : [email protected]
