What product do you wish to discuss? RAK4631
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)? I have flashed the following firmware: WisBlock/bootloader/RAK4630/Latest/wiscore_rak4631_board_bootloader-0.4.3_s140_6.1.1.zip at master · RAKWireless/WisBlock · GitHub
What firmware version? Can it be obtained with AT+VER=?
it cannot as the serial interface doesn’t seem to respond. -
Computer OS? Linux
What Computer OS version? The latest Raspberry Pi os (6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux)
How often does the problem happen? Every time
How can we replicate the problem?
I plug in the RAK to a USB port on my Raspberry pi 4. It powers on and appears as /dev/ttyACM0 my user is in the dialout group which has read and write permission to the device in question and I have rebooted it several times in this configuration as well as I have attempted to unplug the usb cable to cycle power. No battery is connected, the device is configured and shows up as a neighbor on my other nodes. when attempting to use the meshtastic CLI I consistently get timeouts and the device mounts /media/username/RAK4361 as a drive. I assume this indicates its booting into DFU mode. I have been able to connect to the device with BLE on my phone and have setup all the basics, node name, mode Router-Client and of course my region US. -
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
meshtastic --port /dev/ttyACM0
File “/home/k2exe/.local/bin/meshtastic”, line 8, in
sys.exit(main())
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/main.py”, line 1519, in main
common()
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/main.py”, line 1052, in common
client = meshtastic.serial_interface.SerialInterface(
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/serial_interface.py”, line 64, in init
StreamInterface.init(
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/stream_interface.py”, line 50, in init
self.connect()
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/stream_interface.py”, line 74, in connect
self._waitConnected()
File “/home/k2exe/.local/pipx/venvs/meshtastic/lib/python3.11/site-packages/meshtastic/mesh_interface.py”, line 653, in _waitConnected
raise MeshInterface.MeshInterfaceError(“Timed out waiting for connection completion”)
meshtastic.mesh_interface.MeshInterface.MeshInterfaceError: Timed out waiting for connection completion
