We want to know which end device has sent data via the log of a gateway(RAK7268V2), but current log seems to be crude/brief on DEBUG mode(Log level).
Could you tell me how to configure RAK7268V2 then the log can show more information including DevAddr, FCnt and so on for each end device?
Thanks a lot.
Hi @Django ,
Thank you for contacting us regarding the the gateway RAK7268V2.
You will need to set-up the gateway on debug mode through the configuration tab here:
In the system log you will find device address of the mode which was received by the gateway.
Hope this helps!
Kind regards,
Ivan
