How can I program the RAK3172 board as a standalone device without using the WisDuo board?
I bought RAK3172 modul (RAK3172H WisDuo LPWAN Module, 868MHz without IPEX) And I tried upload program. at first I have replaced rak3172 insted of RAK11720 Breakout Board to easy to reach pins and it looks like this:
After that I have updated firmware from STM32 cubeprogrammer it works fine.
RAK---------> ST link
SWDİO ----> DIO
SWCLK —> CLK
3V3 --------> 3V3
GND -------> GND
Actullay there was some problems for BOOT0 and RST pin buf after try and error firmware updated to latest one I can check over the uart1 from esp32. there is no problem.
Problem is I can not directly upload my program over arduino ide now.
this is my USB TTL converter it work with chip marked as 340xe13
USBTTL -----> RAK3172
TXD--------> UART0_RX
RXD -------> UART0_TX
3V3 --------> 3V3
GND ------> GND
I have measure the volt, 3v3 is applied there is no problem.
OUTPUT of Arduino ide
Performing 1200-bps touch reset on serial port COM7
Waiting for upload port...
No upload port found, using COM7 as fallback
"C:\Users\memet\AppData\Local\Arduino15\packages\rak_rui\tools\uploader_ymodem\1.0.1/uploader_ymodem.exe" -f "C:\Users\memet\AppData\Local\Temp\arduino\sketches\B1DE2EEB70DB979A724D3DFA6E8DB156/Arduino_Led_Breathing.ino.bin" -p COM7
Device is not in boot mode
Detecting baudrate..................
Detect baudrate fail, can not get the baudrate
also I can not see the rak3172 in board list of arduino ide 2.3 so I try all 4 option
So how can upload my program with usb ttl converter can you teach me step by step or tutorial
Connect to the RAK3272S Breakout Board
You have to use UART2 pins of the RAK3172. Not UART1. There is no UART0
YOU ARE A-W-E-S-O-M-E. :sunglasses:
last one thing, What is the importance of BOOT0 and RST when flashing with STM32Cubeprogrammer or uploading a program on Arduino, and what is the correct sequence for them?
When you flash with Arduino, BOOT0 should not be touched.
BOOT0 is enabling the STM bootloader, but RUI3 has it’s own bootloader which is started with AT+BOOT (that is what Arduino uploader is sending to the device before it starts uploading).
When flashing with STM32CubeProgrammer over UART, you connect BOOT0 to VCC, then pull RST to GNS (short) to restart the MCU. Then it is in STM bootloader mode which is required by STM32CubeProgrammer.
I am not sure if that is required when you use the SWD interface with STM32CubeProgrammer (I don’t have one). But I think it is not required to use BOOT0 and RST at all.
I am using the SWD interface with JLink, and no additional actions on BOOT0 or RST are required.
Hi @mehmet @beegee ,
When using STLinkV2 on STM32CubeProgrammer via SWD pins, the reset mode can be configured.
Whenever the STLinkV2 connection is failing I connect the RST pin then choice either harware or core reset.
:bowing_man: @carlrowan , our STM32Cube expert :bowing_man:
