When you say manage to get one to work does it mean separate code or in a single code? Since they use SPI bus, take note that it can only communicate to the Core one at a time depending on which is selected via slave select pin.
Hi @carlrowan, what I want is to get the distance (between anchor and tag) using UWB and then I need to transmit the data using the Ethernet(both of them are in the base board dual I/O core). I understood that I can only work with one of them at the time, but is It posible to do what I want? Thanks for your time.
I appreciated, but I am using all your modules (UWB, Ethernet, RAK4631 (core) and Dual I/O base boar) and I need the way to use both UWB - Ethernet.What I found is the I/Os slots are using the same SPI protocol and I am only able to use one of them at the time. Please help me with that.
