I am trying to incorporate a reset into the wisblock nbiot example.
Is using the wisblock-api the way to go, or is there another way to do it?
Get multiple errors trying to use wisblock-api together in my sketch
c:/working_copy_arduino/portable/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: libraries\WisBlock-API\main.cpp.o: in function `setup':
C:\Working_Copy_Arduino\portable\sketchbook\libraries\WisBlock-API\src/main.cpp:66: multiple definition of `setup'; sketch\Wisblock_Davis_Weather_Station_NBIOT_V3.ino.cpp.o:C:\Users\DEV~1.STE\AppData\Local\Temp\arduino_modified_sketch_868435/Wisblock_Davis_Weather_Station_NBIOT_V3.ino:93: first defined here
c:/working_copy_arduino/portable/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: libraries\WisBlock-API\main.cpp.o: in function `loop':
C:\Working_Copy_Arduino\portable\sketchbook\libraries\WisBlock-API\src/main.cpp:217: multiple definition of `loop'; sketch\Wisblock_Davis_Weather_Station_NBIOT_V3.ino.cpp.o:C:\Users\DEV~1.STE\AppData\Local\Temp\arduino_modified_sketch_868435/Wisblock_Davis_Weather_Station_NBIOT_V3.ino:182: first defined here
c:/working_copy_arduino/portable/packages/rakwireless/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lnrf_cc310_0.9.13-no-interrupts
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board WisBlock RAK4631.
