I am using interrupt on a pin with following RUI command but I want to disable interrupt, placing false in below command does not disabling interrupt, is there any other command ?
@Telekonix
There is no support for uninitialized interrupts. If you do not need an interrupt, do not configure it as an interrupt when initializing, or do a gpio uninitialized operation on this pin.
I need Interrupt but, I am going to use same pin for different purpose depend on some conditions, so In program I want to change the pin direction, and use it as Output. isn’t it possible ? How can I perform GPIO un-initialisation. ?
