What product do you wish to discuss? RAK463
What firmware are you using? VSCode/latformIO
What firmware version?
Computer OS? (MacOS, Linux, Windows) Windows
What Computer OS version? Windows 11
How often does the problem happen? Always
How can we replicate the problem? Yes
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
I read in a ST forum that the Device Register responsable by INT2 it is LIS3DH_CTRL_REG6. The value is defined at he library SparkFunLIS3DH.h. Could I redefine the value using Platformio.ini as the example below? What is the best method to do these configurations?
I found the LIS3DH documentation and there I found the INT1/INT2 registers status behavior control: https://cdn.sparkfun.com/assets/learn_tutorials/5/9/6/LIS3DH_AppNote_DocID_18198rev1.pdf
I am trying to do this avoid, when it is possible, the conflicts in the nRF52840 pins.
Regards,
Cláudio
Blockquote
build_flags =
-D MONITOR_SPEED=115200
-D UPLOAD_SPEED=115200
; LEDs
-D LED_GREEN=35
-D LED_BLUE=36
; calibração das variáveis ambientais
-D SEALEVELPRESSURE_HPA=1010.0
; Desabilitar INT2 no RAK1904 para evitar conflito com RAK5801
; -D LIS3DH_CTRL_REG6=0x25
Blockquote
The library SparkFunLIS3DH.h
Blockquote
//Device Registers
#define LIS3DH_STATUS_REG_AUX 0x07
#define LIS3DH_OUT_ADC1_L 0x08
#define LIS3DH_OUT_ADC1_H 0x09
#define LIS3DH_OUT_ADC2_L 0x0A
#define LIS3DH_OUT_ADC2_H 0x0B
#define LIS3DH_OUT_ADC3_L 0x0C
#define LIS3DH_OUT_ADC3_H 0x0D
#define LIS3DH_INT_COUNTER_REG 0x0E
#define LIS3DH_WHO_AM_I 0x0F
#define LIS3DH_TEMP_CFG_REG 0x1F
#define LIS3DH_CTRL_REG1 0x20
#define LIS3DH_CTRL_REG2 0x21
#define LIS3DH_CTRL_REG3 0x22
#define LIS3DH_CTRL_REG4 0x23
#define LIS3DH_CTRL_REG5 0x24
#define LIS3DH_CTRL_REG6 0x25
#define LIS3DH_REFERENCE 0x26
#define LIS3DH_STATUS_REG2 0x27
#define LIS3DH_OUT_X_L 0x28
#define LIS3DH_OUT_X_H 0x29
#define LIS3DH_OUT_Y_L 0x2A
#define LIS3DH_OUT_Y_H 0x2B
#define LIS3DH_OUT_Z_L 0x2C
#define LIS3DH_OUT_Z_H 0x2D
#define LIS3DH_FIFO_CTRL_REG 0x2E
#define LIS3DH_FIFO_SRC_REG 0x2F
#define LIS3DH_INT1_CFG 0x30
#define LIS3DH_INT1_SRC 0x31
#define LIS3DH_INT1_THS 0x32
#define LIS3DH_INT1_DURATION 0x33
#define LIS3DH_CLICK_CFG 0x38
#define LIS3DH_CLICK_SRC 0x39
#define LIS3DH_CLICK_THS 0x3A
#define LIS3DH_TIME_LIMIT 0x3B
#define LIS3DH_TIME_LATENCY 0x3C
#define LIS3DH_TIME_WINDOW 0x3D
Blockquote
