How to flash arduino/standard bootloader
Hello, unfortunately I bought 2 x RAK4630 with RUI3 instead of std bootloader.
I followed the instruction to convert RAK4631-R to RAK4631 given here : RAK4631-R WisBlock LoRaWAN Module DFU | Firmware & Bootloader Update.
The first part were OK and the bootloader falshed to the RAK module.
After, the RAK were well detected by Windows after 2 quick push on the button.
At the end of UF2 file copy on the RAK The windows closes but the file is not copied and the RAK is no more detected as com port by windows.
I can’t do nothing now as I can access to the RAK thru com port.
How is it possible to restore the window USB detection ?
Thank for your help
Pascal
Solved, using Rpi solution.
