Hardware: 18032(ultrasonic) 18003(interposer with FPC and SD) 19007 (esp32 WiFi)
here is my code
@file RecordToSD.ino
@author rakwireless.com
@brief This example shows how to record sound to SD card.
First, you need to prepare the hardware module and SD card.
Step 1: Compile and download the example to RAK11200.
Part 2: Reset RAK11200 and open the serial port.
Part 3: When the serial port prints out "Recording started", the microphone starts to collect sound,
and the default sampling time is 8 seconds.
Step 4: When the serial port prints "Recording finished", the microphone completes the recording and
stores the audio data to the SD card.
Part 5: Insert the SD card into the player to play the WAV format audio file you have recorded,
the default file name is "record.wav".
@note This example need use the microphone module and RAK18003 module.
@version 0.1
@date 2022-06-6
@copyright Copyright (c) 2022
#include "audio.h"
#include <driver/i2s.h>
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include "PDM.h"
#include <string.h>
File new_audio_file;
// default number of output channels
static const int channels = 1;
// default PCM output frequency
static const int frequency = 96000; // 48000 have also tried.
#define BIT_PER_SAMPLE 16
#define RECORD_TIME 30 //recording time default 8 seconds
TPT29555 Expander1(0x23);
TPT29555 Expander2(0x25);
void RAK18003Init(void);
void microphone_record(const char* song_name, uint32_t duration);
bool create_wav_file(const char* song_name, uint32_t duration, uint16_t num_channels, const uint32_t sampling_rate, uint16_t bits_per_sample);
void SD_CS_low();
void SD_CS_high();
void generate_file_name(const char *dirname, char file_name[]);
void setup() {
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, HIGH);
delay(500);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
digitalWrite(LED_BLUE, LOW);
digitalWrite(LED_GREEN, LOW);
time_t timeout = millis();
while (!Serial)
if ((millis() - timeout) < 1000)
delay(100);
else
break;
Serial.println("==========Record To SD example============");
RAK18003Init();
SD_CS_low(); //enable the SPI CS
if (!SD.begin(SS, SPI, 8000000, "/sd", 5)) { // Start access to the SD.
Serial.println("Card Mount Failed");
if (SD.exists("/record.wav")) {
Serial.println("Remove file first!");
SD.remove("/record.wav");
char file_name[200] = "";
generate_file_name("/", file_name);
const char* song_name = file_name;
// initialize PDM with:
if (!PDM.begin(channels, frequency)) {
Serial.println("Failed to start PDM!");
while (1) yield();
microphone_record(song_name, RECORD_TIME); //the default record file name is "record.wav".
SD_CS_high(); //disable the SPI CS
void loop()
while (!Expander1.begin())
Serial.println("Did not find RAK18003 IO Expander Chip1,please check!");
digitalWrite(LED_BLUE, HIGH);
digitalWrite(LED_GREEN, HIGH);
delay(200);
delay(200);
while (!Expander2.begin())
Serial.println("Did not find RAK18003 IO Expander Chip2,please check!");
delay(200);
delay(200);
Expander1.pinMode(0, INPUT); //SD check
Expander1.pinMode(1, INPUT); //MIC check
Expander1.pinMode(2, INPUT); //MIC CTR1
Expander1.pinMode(3, INPUT); //MIC CTR2
Expander1.pinMode(4, INPUT); //AMP check
Expander1.pinMode(5, INPUT); //AMP CTR1
Expander1.pinMode(6, INPUT); //AMP CTR2
Expander1.pinMode(7, INPUT); //AMP CTR3
Expander1.pinMode(8, INPUT); //DSP check
Expander1.pinMode(9, INPUT); //DSP CTR1 DSP int
Expander1.pinMode(10, INPUT); //DSP CTR2 DSP ready
Expander1.pinMode(11, INPUT); //DSP CTR3 DSP reset
Expander1.pinMode(12, INPUT); //DSP CTR4 not use
Expander1.pinMode(13, INPUT); //DSP CTR5 not use
Expander1.pinMode(14, INPUT); //NOT USE
Expander1.pinMode(15, INPUT); //NOT USE
Expander2.pinMode(0, OUTPUT); //CORE SPI CS1 DSP CS
Expander2.pinMode(1, OUTPUT); //CORE SPI CS2
Expander2.pinMode(2, OUTPUT); //CORE SPI CS3
Expander2.pinMode(3, OUTPUT); //PDM switch CTR 1 to dsp 0 to core
Expander2.pinMode(4, OUTPUT); //not use
Expander2.pinMode(5, OUTPUT); //not use
Expander2.pinMode(6, OUTPUT); //not use
Expander2.pinMode(7, OUTPUT); //not use
Expander2.pinMode(8, OUTPUT); //not use
Expander2.pinMode(9, OUTPUT); //not use
Expander2.pinMode(10, OUTPUT); //not use
Expander2.pinMode(11, OUTPUT); //not use
Expander2.pinMode(12, OUTPUT); //not use
Expander2.pinMode(13, OUTPUT); //not use
Expander2.pinMode(14, OUTPUT); //not use
Expander2.pinMode(15, OUTPUT); //not use
Expander2.digitalWrite(3, 0); //set the PDM data direction from MIC to WisCore
while (Expander1.digitalRead(1) == 0) //Check if the microphone board is connected on the RAK18003
Serial.println("There is no microphone, please check !");
// Serial.println(Expander1.readAllPin());
// Serial.println(Expander1.digitalRead(1));
// Serial.println(Expander1.readReg(1));
delay(500);
while(Expander1.digitalRead(0) == 1) //Check SD card
Serial.println("There is no SD card on the RAK18003 board, please check !");
delay(500);
void SD_CS_high()
Expander2.digitalWrite(2, 1);
void SD_CS_low()
Expander2.digitalWrite(2, 0);
// Create a file and add wav header to it so we can play it from PC later
bool create_wav_file(const char* song_name, uint32_t duration, uint16_t num_channels, const uint32_t sampling_rate, uint16_t bits_per_sample) {
// data size in bytes - > this amount of data should be recorded from microphone later
uint32_t data_size = sampling_rate * num_channels * bits_per_sample * duration / 8;
new_audio_file = SD.open(song_name, FILE_WRITE);
if (new_audio_file == NULL) {
Serial.println("Failed to create file");
return false;
/* *************** ADD ".WAV" HEADER *************** */
uint8_t CHUNK_ID[4] = {'R', 'I', 'F', 'F'};
new_audio_file.write(CHUNK_ID, 4);
uint32_t chunk_size = data_size + 36;
uint8_t CHUNK_SIZE[4] = {chunk_size, chunk_size >> 8, chunk_size >> 16, chunk_size >> 24};
new_audio_file.write(CHUNK_SIZE, 4);
uint8_t FORMAT[4] = {'W', 'A', 'V', 'E'};
new_audio_file.write(FORMAT, 4);
uint8_t SUBCHUNK_1_ID[4] = {'f', 'm', 't', ' '};
new_audio_file.write(SUBCHUNK_1_ID, 4);
uint8_t SUBCHUNK_1_SIZE[4] = {0x10, 0x00, 0x00, 0x00};
new_audio_file.write(SUBCHUNK_1_SIZE, 4);
uint8_t AUDIO_FORMAT[2] = {0x01, 0x00};
new_audio_file.write(AUDIO_FORMAT, 2);
uint8_t NUM_CHANNELS[2] = {num_channels, num_channels >> 8};
new_audio_file.write(NUM_CHANNELS, 2);
uint8_t SAMPLING_RATE[4] = {sampling_rate, sampling_rate >> 8, sampling_rate >> 16, sampling_rate >> 24};
new_audio_file.write(SAMPLING_RATE, 4);
uint32_t byte_rate = num_channels * sampling_rate * bits_per_sample / 8;
uint8_t BYTE_RATE[4] = {byte_rate, byte_rate >> 8, byte_rate >> 16, byte_rate >> 24};
new_audio_file.write(BYTE_RATE, 4);
uint16_t block_align = num_channels * bits_per_sample / 8;
uint8_t BLOCK_ALIGN[2] = {block_align, block_align >> 8};
new_audio_file.write(BLOCK_ALIGN, 2);
uint8_t BITS_PER_SAMPLE[2] = {bits_per_sample, bits_per_sample >> 8};
new_audio_file.write(BITS_PER_SAMPLE, 2);
uint8_t SUBCHUNK_2_ID[4] = {'d', 'a', 't', 'a'};
new_audio_file.write(SUBCHUNK_2_ID, 4);
uint8_t SUBCHUNK_2_SIZE[4] = {data_size, data_size >> 8, data_size >> 16, data_size >> 24};
new_audio_file.write(SUBCHUNK_2_SIZE, 4);
// Actual data should be appended after this point later
new_audio_file.close();
return true;
void microphone_record(const char* song_name, uint32_t duration) {
// Add wav header to the file so we can play it from PC later
// if (!create_wav_file(song_name, duration, channels, frequency, BIT_PER_SAMPLE)) {
// Serial.println("Error during wav header creation");
// return;
//Extract mono data from stereo
if (!create_wav_file(song_name, duration, 1, frequency, BIT_PER_SAMPLE)) {
return;
// Buffer to receive data from microphone
const size_t fifo_size = 512;
uint8_t* buf = (uint8_t*)malloc(fifo_size);
// Open created .wav file in append+binary mode to add PCM data
File audio_file = SD.open(song_name, FILE_APPEND);
if (audio_file == NULL) {
return;
uint32_t data_size = frequency * BIT_PER_SAMPLE * duration / 8;
// Record until "file_size" bytes have been read from mic.
uint32_t counter = 0;
Serial.println("Recording started");
while (counter != data_size) {
// Check for file size overflow
if (counter > data_size) {
Serial.println("File is corrupted. data_size must be multiple of fifo_size. Please modify fifo_size");
break;
// Read data from microphone
int bytes_read = PDM.read(buf, fifo_size);
if (bytes_read > 0)
for (int i = 0; i < fifo_size; i++)
buf[i] = buf[i] << 1; //2x the original volume
// Serial.print("Buf: ");
// Serial.println(buf[i]);
if (channels == 2)
const size_t write_size = bytes_read >> 1;
uint8_t* write_buf = (uint8_t*)malloc(write_size);
for (int i = 0; i < (write_size >> 1); i++) //Convert stereo data to mono
write_buf[i * 2] = buf[i * 4];
write_buf[i * 2 + 1] = buf[i * 4 + 1];
// Save data to SD card
audio_file.write(write_buf, write_size);
// Increment the counter
counter += write_size;
free(write_buf);
else
audio_file.write(buf, fifo_size);
counter += fifo_size;
Serial.println("Recording finished");
audio_file.close();
PDM.end();
free(buf);
File root = SD.open(dirname);
if (!root) {
Serial.println("Failed to open directory");
return;
if (!root.isDirectory()) {
Serial.println("Not a directory");
return;
File file;
int idx = 0;
while (file = root.openNextFile())
if (!file.isDirectory())
const char* name = file.name();
Serial.println(file.name());
char* _name = strdup(name);
char* token = strtok(_name, "_.");
Serial.println(token);
while (token != nullptr)
token = strtok(NULL,"_.");
if (isdigit(*token))
int _idx = atoi(token);
Serial.print("_idx = ");
Serial.println(_idx);
if (_idx > idx)
idx = _idx;
break;
idx++;
Serial.print("idx = ");
Serial.println(idx);
// char file_name[100];
sprintf(file_name,"/record_%d.wav",idx);
Serial.println(file_name);
However, the recorded wav file does not output correct sound. It seems to have no sound at all. When I navigate to other timestamp, it has current noise. Can anyone tell me what is wrong?
