I am testing with the example LoRaWAN_OTAA_ABP sketch version 0.1 and US915 frequency band.
I have discovered that if I attempt to send more than 7 bytes, the lmh_send() function throws an error.
NOTE that if I send exactly 8 bytes, the first send is successful, but subsequent attempts to send fail.
If I send more than 8 bytes, the first and all subsequent sends fail immediately.
Is this 7-byte limit a product of the LoRaWAN maximum payload size of 11 bytes for US915 at D0?
If this is the case, why isn’t this mentioned somewhere within the sketch? Instead, the m_lora_app_data.buffer variable is declared to be 64 bytes in size with no mention that it must be only 7 bytes or fail will occur.
Also, is this a fixed limitation? I.e. will the limit always be 7 bytes, or will this change based on some unknown property, header, or length of another value that is being sent?
Yes, it is based on Duty Cycle and Dwell Time restrictions LoRaWAN.
I am not sure why you are getting failures in 8 bytes size but I think that is a different issue.
At DR0, you should be able to send successfuly up to 11 bytes.
switch (error)
case LMH_SUCCESS:
Serial.println("Packet enqueued");
count++;
break;
case LMH_BUSY:
Serial.println("LoRa transceiver is busy");
count_fail++;
break;
case LMH_ERROR:
Serial.println("Packet error, too big to send with current DR");
count_fail++;
break;
I have modified the code per your request and here are the results:
7 bytes: send OK (repeated sending is successful)
8 bytes to 11 bytes: first send OK, subsequent sends fail with error code “-1”
12+ bytes: error code “-1” on every attempt
To confirm, at no time does it report “Busy”. Always Error “-1”.
