Hello, is there a way to restart/reset the Wisblock 4630 (i.e. soft reset) from within the software? For example, 1) I would like to set a watchdog that resets the chip if my user-code hangs, and 2) I would like to be able to send a restart command remotely to the unit via LoRa.
I found this on the FreeRTOS forum, but it’s quite old, and also a bit confusing.
I also found this on the RAK forum regarding an implementation of WDT.
However, still looking for info on initiating a soft reset manually via code.
