How to use LTE function on RAK7243/Pilot gateway pro
#!/bin/sh
cd /sys/class/gpio/
echo 5 > export
echo 6 > export
echo 13 > export
echo 18 > export
echo 19 > export
echo 21 > export
echo 26 > export
echo out > gpio5/direction
echo out > gpio6/direction
echo out > gpio13/direction
echo out > gpio18/direction
echo out > gpio19/direction
echo in > gpio21/direction
echo out > gpio26/direction
echo 0 > gpio5/value
echo 0 > gpio6/value
echo 0 > gpio13/value
echo 0 > gpio19/value
echo 0 > gpio26/value
echo 1 > gpio18/value
sleep 1
echo 0 > gpio18/value
sleep 1
now a get this :
pi@rak-gateway:~ $ sudo pppd call gprs
pppd options in effect:
debug # (from /etc/ppp/peers/gprs)
nodetach # (from /etc/ppp/peers/gprs)
dump # (from /etc/ppp/peers/gprs)
noauth # (from /etc/ppp/peers/gprs)
remotename 3gppp # (from /etc/ppp/peers/gprs)
/dev/ttyAMA0 # (from /etc/ppp/peers/gprs)
115200 # (from /etc/ppp/peers/gprs)
lock # (from /etc/ppp/peers/gprs)
connect chat -s -v -f /etc/chatscripts/quectel-chat-connect -T mmsbouygtel # (from /etc/ppp/peers/gprs)
disconnect chat -s -v -f /etc/chatscripts/quectel-chat-disconnect # (from /etc/ppp/peers/gprs)
nocrtscts # (from /etc/ppp/peers/gprs)
modem # (from /etc/ppp/peers/gprs)
asyncmap 0 # (from /etc/ppp/options)
lcp-echo-failure 4 # (from /etc/ppp/options)
lcp-echo-interval 30 # (from /etc/ppp/options)
hide-password # (from /etc/ppp/peers/gprs)
novj # (from /etc/ppp/peers/gprs)
novjccomp # (from /etc/ppp/peers/gprs)
ipcp-accept-local # (from /etc/ppp/peers/gprs)
ipcp-accept-remote # (from /etc/ppp/peers/gprs)
ipparam 3gppp # (from /etc/ppp/peers/gprs)
noipdefault # (from /etc/ppp/peers/gprs)
ipcp-max-failure 30 # (from /etc/ppp/peers/gprs)
defaultroute # (from /etc/ppp/peers/gprs)
usepeerdns # (from /etc/ppp/peers/gprs)
noccp # (from /etc/ppp/peers/gprs)
noipx # (from /etc/ppp/options)
abort on (BUSY)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (ERROR)
abort on (NO ANSWER)
timeout set to 30 seconds
send (AT^M)
expect (OK)
^M
– got it
send (ATE0^M)
expect (OK)
^M
^M
– got it
send (ATI;+CSUB;+CSQ;+COPS?;+CGREG?;&D2^M)
expect (OK)
^M
^M
Quectel^M
EG95^M
Revision: EG95EFBR06A05M4G^M
^M
SubEdition: V01^M
^M
+CSQ: 20,99^M
^M
+COPS: 0^M
^M
+CGREG: 0,2^M
^M
– got it
send (AT+CGDCONT=1,“IP”,“mmsbouygtel”,0,0^M)
expect (OK)
^M
^M
– got it
send (ATD*99#^M)
expect (CONNECT)
^M
^M
CONNECT
– got it
Script chat -s -v -f /etc/chatscripts/quectel-chat-connect -T mmsbouygtel finished (pid 907), status = 0x0
Serial connection established.
using channel 4
Using interface ppp0
Connect: ppp0 <–> /dev/ttyAMA0
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xe6a28b1e> ]
rcvd [LCP ConfReq id=0x9 <asyncmap 0x0> <magic 0xd126d265> ]
No auth is possible
sent [LCP ConfRej id=0x9 ]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xe6a28b1e> ]
rcvd [LCP ConfReq id=0xa <asyncmap 0x0> <magic 0xd126d265> ]
sent [LCP ConfAck id=0xa <asyncmap 0x0> <magic 0xd126d265> ]
sent [LCP EchoReq id=0x0 magic=0xe6a28b1e]
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
rcvd [LCP DiscReq id=0xb magic=0xd126d265]
rcvd [LCP EchoRep id=0x0 magic=0xd126d265 e6 a2 8b 1e]
sent [LCP EchoReq id=0x1 magic=0xe6a28b1e]
IPCP: timeout sending Config-Requests
sent [LCP TermReq id=0x2 “No network protocols running”]
sent [LCP TermReq id=0x3 “No network protocols running”]
Connection terminated.
abort on (ERROR)
unterminated quote (line 4)
Script chat -s -v -f /etc/chatscripts/quectel-chat-disconnect finished (pid 916), status = 0x1
disconnect script failed
Modem hangup
1.Can you send the prints of the 4) and 5) steps?
2.Can you send the contents of file “/etc/ppp/peers/gprs”?
hello, it work fine when a disconnet the wifi and reboot. thank for your help I really appreciate
@Fomi
I’m stuck here. Any help would be very helpful.
I’m not even able to give AT commands, the window is stuck after
“minicom -D /dev/ttyAMA0 -b 115200”
command.
Hi, @sri
I think maybe you can use the latest firmware for RAK7243 with LTE:
https://www.rakwireless.com/en/download/LoRa/Pilot-Gateway-Pro-RAK7243#Firmware
Please download the one named “RAK7243_LTE_…” .
In the latest firmware, we’ve added a configuration UI, so you can configure it easily now.
Thanks @Fomi now I can see all the 3 LEDs light up but connect script failed error.
The Cellular Module doesn’t connect to the internet. Any thoughts?
Hi, @sri
Can you execute the following command?
sudo minicom -D /dev/ttyAMA0 -b 115200
and type:
ATI
Then give me the log picture.
Thank you!
@Fomi
Please find the result.
51%20PM
Hardly the cmd prompt is interactive if I enter the minicom cmd.
Thank you.
Revision info came after I hit another key stroke:
Quectel
BG96
Revision: BG96MAR02A07M1G
When I hit “sudo pppd call gprs”
It fails like this:
Hi, @sri
You can type “at+cops=?” to get a network operator information, for example, i can get the following information in China:
2,“CHN-CT”,“CT”,“46011”,7
I think you can get some information like this too.
If it is, please type “at+cops=1,0,xxx,yyy” to set your network operator. “xxx” is the one you get in the last step, like “CHN-CT”, and “yyy” is the one like “7” according to my example.
When you complete these step correctly, you can set APN name on the UI, then restart the device.
Please try again.
Hi, @Fomi
This is the error I get.
Can you try to use another Network operator? For example, IDEA.
Sure, let me insert the SIM and let you know. Even if LTE is not connecting it should latch on to EGSM on 900 band.
@Fomi I got OK with Idea, but no connectivity.
Executed “sudo pppd call gprs” and I get OK OK and fail this time too.
The Gateway is going up when on WiFi but on cellular ‘No’.
Yesterday you have used the at command to configure IDEA successfully.
Can you try the following steps?
1.reboot gateway
2.Use “sudo gateway-config”,choose “Configure LTE module”, choose “Disable LTE…”
3.Choose “Configure LTE module”, choose “Active LTE module”
4.Use “sudo gateway-config”,choose “Configure APN name”,reset the APN name “IDEA”
5.reboot gateway
6.Use “sudo gateway-config”,Choose “Configure LTE module”, choose “Active LTE module”
7.Use “sudo pppd call gprs”,Can it be successful?
@ZhuQI thanks for your reply ZhuQI,
Yes, I have been trying since 3 days various steps, in-fact the above steps as well, but they yielded no result.
Do you know anyone from India who was able to successfully use gprs? any help is appreciated.
Thank you much.
Sri
I am trying same thing but not working , here is my pppd call gprs output :
and ends with
sent [LCP EchoReq id=0x1 magic=0xe30aeae7]
abort on (ERROR)
Script chat -s -v -f /etc/chatscripts/quectel-chat-disconnect finished (pid 1070), status = 0x1
Modem hangup
how can i proceed on it
I’m reaching CGREG Ok, but when trying to Connect:
send (AT+CGDCONT=1,"IP","gprs.movistar.com.ar",,0,0^M)
expect (OK)
^M
^M
ERROR
 -- FAILED
Failed (ERROR)
Script chat -s -v -f /etc/chatscripts/quectel-chat-connect -T gprs.movistar.com.ar finished (pid 997), status = 0x7
Connect script failed
Does anyone have an idea of what may be happening?
Thanks in advance
I am sorry to see your post so late.
Can you post the print of “at+cops=?”?
