@Fomi I got OK with Idea, but no connectivity.
Executed “sudo pppd call gprs” and I get OK OK and fail this time too.
The Gateway is going up when on WiFi but on cellular ‘No’.
Yesterday you have used the at command to configure IDEA successfully.
Can you try the following steps?
1.reboot gateway
2.Use “sudo gateway-config”,choose “Configure LTE module”, choose “Disable LTE…”
3.Choose “Configure LTE module”, choose “Active LTE module”
4.Use “sudo gateway-config”,choose “Configure APN name”,reset the APN name “IDEA”
5.reboot gateway
6.Use “sudo gateway-config”,Choose “Configure LTE module”, choose “Active LTE module”
7.Use “sudo pppd call gprs”,Can it be successful?
@ZhuQI thanks for your reply ZhuQI,
Yes, I have been trying since 3 days various steps, in-fact the above steps as well, but they yielded no result.
Do you know anyone from India who was able to successfully use gprs? any help is appreciated.
Thank you much.
Sri
I am trying same thing but not working , here is my pppd call gprs output :
and ends with
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
sent [LCP EchoReq id=0x1 magic=0xe30aeae7]
IPCP: timeout sending Config-Requests
sent [LCP TermReq id=0x2 “No network protocols running”]
sent [LCP TermReq id=0x3 “No network protocols running”]
Connection terminated.
abort on (ERROR)
abort on (NO DIALTONE)
unterminated quote (line 4)
Script chat -s -v -f /etc/chatscripts/quectel-chat-disconnect finished (pid 1070), status = 0x1
disconnect script failed
Modem hangup
how can i proceed on it
I’m reaching CGREG Ok, but when trying to Connect:
send (AT+CGDCONT=1,"IP","gprs.movistar.com.ar",,0,0^M)
expect (OK)
^M
^M
ERROR
-- FAILED
Failed (ERROR)
Script chat -s -v -f /etc/chatscripts/quectel-chat-connect -T gprs.movistar.com.ar finished (pid 997), status = 0x7
Connect script failed
Does anyone have an idea of what may be happening?
Thanks in advance
I am sorry to see your post so late.
Can you post the print of “at+cops=?”?
