Issue: The GPS stop working because the I2C stuck. The major problem is that the only way to recover from that is turn off the gateway (reboot does not fix it)
Setup: RAK7244C (also occur for me in 7243C see RAK7243 - GPS stop working)
Details: When the GPS stop working I test the I2C with sudo i2cdetect -y 1 and no address detected
I can split the issue to 2 -
- what cause it to stuck
- way to recover
the second one is more critical because I connected remotely and now the only way to fix it is turn off…
