Issue:LoRa range not enough
Setup:RAK831 as gateway, RAK811 as lora nodes and RAK firmware used for gateway
Server:TTN
Details: I used above setup for small pilot project but most of node are out of range from gateway. What should I done to improve the range?
Also I want to know is there any most suitable configuration to improve communication distance of node by changing data rate with output power.
If we used high gain antenna for gateway, will it can improve the communication distance of LoRa
