RAK4630 includes nRF52840 SoC and SX1262 LoRa transceiver. How does nRF52840 connect to SX1262 internally? Is it SPI?
Yes, it is SPI.
The pin assignment can be found in the LoRaWAN library SX126x-Arduino
_hwConfig.CHIP_TYPE = SX1262; // Chip type, SX1261 or SX1262
_hwConfig.PIN_LORA_RESET = 38; // LORA RESET
_hwConfig.PIN_LORA_NSS = 42; // LORA SPI CS
_hwConfig.PIN_LORA_SCLK = 43; // LORA SPI CLK
_hwConfig.PIN_LORA_MISO = 45; // LORA SPI MISO
_hwConfig.PIN_LORA_DIO_1 = 47; // LORA DIO_1
_hwConfig.PIN_LORA_BUSY = 46; // LORA SPI BUSY
_hwConfig.PIN_LORA_MOSI = 44; // LORA SPI MOSI
_hwConfig.RADIO_TXEN = -1; // LORA ANTENNA TX ENABLE
_hwConfig.RADIO_RXEN = 37; // LORA ANTENNA RX ENABLE (power for antenna switch)
_hwConfig.USE_DIO2_ANT_SWITCH = true; // LORA DIO2 controls antenna
_hwConfig.USE_DIO3_TCXO = true; // LORA DIO3 controls oscillator voltage
_hwConfig.USE_DIO3_ANT_SWITCH = false; // LORA DIO3 controls antenna
_hwConfig.USE_RXEN_ANT_PWR = true; // RXEN is used as power for antenna switch
_hwConfig.USE_LDO = false; // LORA usage of LDO or DCDC power regulator (defaults to DCDC)
Thanks again, Bernd.
