Hi, I use Chirpstack Server + RAK7246 + RAK11310 + RAK19007 to control relay.
I take “LoRaWAN_OTAA_ABP” example and add:
setup
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, HIGH);
pinMode(WB_IO4, OUTPUT);
loop
"void lorawan_rx_handler(lmh_app_data_t *app_data)
Serial.printf(“LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d, data:%s\n”,
uint8_t relay_command = *app_data->buffer;
if(relay_command==1)
Serial.println(“LED on”);
digitalWrite(WB_IO4, LOW);
else
Serial.println(“LED off”);
digitalWrite(WB_IO4, HIGH);
It’s worked, i can send commands to relay, but I noticed that not all commands are executed, the gateway sends commands, but the relay does not respond, sometimes more often, sometimes less often, I can’t find the dependency. Maybe it’s something in the loop code, the rx command comes at the wrong time and ignored, but my knowledge is not enough to understand how to fix it.
Pls, help newbie
